Old 12-05-2003, 04:06 AM   #1
Orence1
Orence1's Avatar
Lowering and pinion angle
Want to do a 4"/5" drop on my 72 LWB Cheyenne soon. Dropped spindles and lowered springs all around. My concern is the changes it will make in driveshaft angles. Truck is a 402/Th-350 combo and has a newly rebuilt/shortened two piece driveshaft. Do I need to be concerned about this and can any of you provide me with some advance input?
Thanks,
Larry
Orence1 is offline   Reply With Quote
Old 12-05-2003, 04:57 AM   #2
PR454SS
PR454SS's Avatar
Yes you need to be concerned with pinion angle as it will cause vibration, ideally the pinion needs to have between 0 and 3 degrees downward tilt (at the u-joint yoke) at ride height for a street truck.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-05-2003, 10:51 AM   #3
tom hand
CCRider
tom hand's Avatar
Yes it is a concern....I had a lowered 71 and it constantly ate rear u-joints....averaged two years between changes. You need wedges to change the angle. This page is for big trucks but has a lot of good imformation.
http://www.drivetrain.com/driveline_angle_problem.html
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-05-2003, 03:20 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Orence1. Did you notice that we have our drop spindles on sale? If you need a set you aught to come on down and take a look. Lifetime Gaurantee USA made drop spindles $194.95 per set. Lots of them in stock also. Just a FYI responce.
http://www.classicheartbeat.com/specials.htm
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-06-2003, 12:43 AM   #5
Orence1
Orence1's Avatar
Thanks for the help guys. I will keep this in mind when I do the conversion. And Wes, thanks for the heads up on the spindles.
Larry
Old 12-06-2003, 12:48 AM   #6
gr8scott51
gr8scott51's Avatar
No problem here.
Larry, After I dropped mine, I checked my pinion angle. Maybe I just got lucky, but it was within tolerance. Scott
get my pm?
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
