Old member
This is the second dash outer shell I have found like this.
Why is the steering column part not cutout? I can't figure it out why it would have been sold. Just makes me wonder. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Feb 2014
Re: Explain this please...
Andy, that's a bezel for a c40+ The firewall and angle of the steering column were different then the light duty trucks. Hope that helps
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
#3 | |
Old member
![]() Quote:
Well there you go! I never knew this and never looked at a C-40 i guess. Thanks I learned something today! ![]()
The Older Generation
Quite a few of the tach dashes you see are from the C-40, 50 & 60 trucks. Unless the bezels have been swapped out, that is how you can tell. No big deal, you can just cut the plastic out to the upper line and put it in..... LockDoc
#5 | |
Old member
![]() Quote:
That's what I'm planning to do. I got a couple of dashes I'm going to repaint and fix up just to have if I ever need one. ![]()
And have as wall hangers till then, right?
Old member
Correct sir!
I have some different paint schemes I want to try out as well . ![]()
Active Member
![]() Join Date: Oct 2002
I pulled a gauge cluster from a medium duty truck, and one of the red warning lights a the bottom of the fuel gauge says (tandem lock) when you start the truck.
So use a fuel gauge from a light duty truck. |
^^^ Or just not a tandem medium duty. I wonder if (single rear) air brake trucks still use the brake warning light
