11-19-2019, 07:22 PM | #1 |
How bad is this cab rust? (Pic)
The worst spot on the truck. Drip rail is good.
11-19-2019, 07:54 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: How bad is this cab rust? (Pic)
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-19-2019, 09:01 PM | #3 |
Like Clyde said, it is repairable. You can just replace that section or you can remove the top roof skin as well and clean that area out and treat it to prevent further rusting. All just depends on how deep you want to get into it.
11-20-2019, 12:09 AM | #4 |
How bad is this inside panel above the windshield ? If the outside is rotted usually the inside panel is rotted out as well. They sell patch panels for both
This is where things start to snowball quick lol |
11-20-2019, 02:53 AM | #5 | |
I have a feeling that mine is gonna be one of those snowballs..... |
11-20-2019, 03:20 AM | #6 | |
https://www.classicparts.com/1960-66...ctinfo/44-195/ |
11-20-2019, 08:09 AM | #7 |
Thanks, jrusher, but I have a 62 that needs an inner patch. I wonder how different the later ones are.... maybe I can make it work.
11-20-2019, 07:22 PM | #8 |
11-20-2019, 11:19 PM | #9 |
Just did my 61 apache,my cab is pretty much done
11-21-2019, 01:11 AM | #10 |
11-21-2019, 01:46 AM | #11 |
Yup,it worked out good,I finished welding it and put some filler,I’m pretty happy with results
11-21-2019, 03:38 AM | #12 |
Oh man, that's good news, thanks!
11-21-2019, 11:37 AM | #13 |
Yes, check down the A pillars all the way to the floor to get your next answer.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
11-21-2019, 12:16 PM | #14 |
Moderator
Mine was worse once. There is nothing time, patience, hard work and resources can't fix.
11-21-2019, 03:27 PM | #15 |
Damn mice crawl up the A pillar and nest. Here’s two roof skins I pulled off one on my 65 and the other was from a donor. They make a repop roof skin as well wish I would of known that before I swapped mine out .
11-21-2019, 06:32 PM | #16 |
what is that around the rear glass inside? More rust?
I thought Cal trucks are supposed to be rust free? Was it parked at the beach? |
