700R speedo conversion; electric to mechanical
Looking for help on how to hook up my original mechanical speedometer cable to an electric 700R transmission.
Re: 700R speedo conversion; electric to mechanical
On mine, 89-90 700r4 ..Take off the tail shaft to get to the metal pickup/gear. slice thru with hacksaw about 1/2" then put chisel in slot and crack the last 1/4" to slide it off the shaft. then you can add the drive gear and the clip. Then you need driven gear housing and the correct color/ tooth count on both of them to match your rear axle gear ratio for the correct speed. I needed longer speedo cable. Also changed the bronze bushing while the tail shaft is off.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
That’s way out of my comfort zone. I’ll probably just try one of those expensive conversion kits. Lol
It's really not that bad, but I did have the trans out at the time....what kind of kit are you talking about? Full electronic dash?
GM Addicted
Call a transmission shop ask them how much to convert it to mechanical not that hard at all. Removed driveline and tail shaft housing.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
![]() Join Date: Jul 2016
You can pull the electric pulse generator off the tailshaft with a harmonic balancer puller and some long bolts. Then just replace it with the speedo drive gear.
Its a Truck Thing......
https://transmissioncenter.net/ is where I got all my conversion parts to do mine. You can call them and they can see exactly what you need.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Does the output shaft have to be modified to accept the new gears?
Here is what it looks like, you could borrow a puller from autozone or oreillys too, need pretty long reach tho.
I have done it like this with long bolts or allthread
#13 |
Nut on the end behind of the allthread or long bolt to pull.
Cable type plastic gear is held in place with a small clip, which engages a hole in the shaft, i dont know if all shafts have the hole though for the clip. |
#14 |
Tail-shaft housing has a square rubber o ring instead of a gasket, its re-usable if needed.
#15 |
The hole for the clip is there in this one, on yours it could be under the gear or whatever its called.
#16 |
Thank you for the detailed information. I’m afraid I’m going to get it apart and find out I don’t have a hole for the clip.
#17 |
I dont know if some dont have a hole or not. Maybe you can look it up.
Jack the rear of the truck up real high and you wont loose hardly any trans fluid. I think there is a trans guy on the forum, clineberger or something like that, he probably knows, kwmech probably knows too, |
#18 |
They all have a hole, You need to know what rear gears,heigth of tires to get the right combo of drive gear and driven gear and the appropriate housing.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
