Old 12-05-2003, 11:05 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Front Springs
Has anybody ever used 3 inch drop springs on the front. I was just wondering if that changes the front suspension geometry to much. Alot of people are using 1 to 2 inch springs with their drop spindles but I was thinking maybe I would try 3 inch. That would be almost a 6/6 drop. Anybody have a truck with this drop that doesnt have bags. I would like to see some pics.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 12-05-2003, 12:21 PM   #2
nightmare
nightmare's Avatar
i've got them installed, but i don't have any rims or tires on the truck yet, so i don't know how much the geometry will be off. i hope it isn't that much.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-05-2003, 03:35 PM   #3
72BLAZERDUDE
What size tires and rims are you goung to run. Are you also running drop spindles. Was thinking about that front offset. Might have to pull those fronts in to be able to turn.
Old 12-05-2003, 05:44 PM   #4
tom hand
CCRider
tom hand's Avatar
It will throw it wayyyyy out of wack. You will have to install longer bolts on the top a-arms to be able to shim it out enough to line it up....don't do it...you will be sorry. If you what to go that low bags are the only way to go
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-05-2003, 07:32 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done it several times. No problems adjusting the camber and caster back to proper specs without any mods to the upper bolts.
Old 12-05-2003, 09:47 PM   #6
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I got 3 inch drop springs on the front of mine. When i went to get the alignment done the guy had to use 12 bucks worth of spacers on the upper A arms to make it work. Don't know if that was just the drop or in a terrible need of an alignment otherwise. Otherwise i don't have any problem with mine. But i got 15 rims. 255x60R15 tires. Hope i helped some.
WRMZ71 is offline   Reply With Quote
