11-23-2019, 11:16 AM | #1 |
Carpe manana
Convert base to deluxe knob?
Curious if anyone has removed the stainless trim button from a deluxe knob? I'm pondering the possibility of adding the stainless trim to a base knob for use on my manual throttle.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-23-2019, 11:59 AM | #2 |
Re: Convert base to deluxe knob?
I’ve seen foil duck work tape on them and it looked pretty nice
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
11-23-2019, 12:18 PM | #3 |
Probably not what your thinking Pete. Lower right, choke cable, glued extra 72 knob on a generic choke cable added aluminum bezel from 64 Impala ? Maybe.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
11-23-2019, 02:39 PM | #4 |
Carpe manana
Thanks for the input guys. I’m curious how the trim is affixed - pressed on or glued? If glue I’ll try to remove after applying a heat gun.
11-23-2019, 05:37 PM | #5 |
BlahBlahBlah
I don’t know if this is throttle or choke. Is this deluxe? The base seems off to me. I know I had been collecting for hand throttle and choke at one time.
11-23-2019, 08:23 PM | #6 | |
It's Deluxe. The Standard knobs are all black plastic. As to the original question: I would just buy Deluxe knobs new from a vendor, rather than mess up Standard knobs. Maybe not as much fun, but lots quicker.
11-23-2019, 09:15 PM | #7 | |
BlahBlahBlah
11-24-2019, 12:53 PM | #8 |
I haven't tried, but I am sure if you soaked in something like lacquer thinner it should dissolve the adhesive and not harm the metal. I think any prying would be out of consideration
11-24-2019, 03:15 PM | #9 |
Carpe manana
Good idea Tim. Thanks. Pete
11-24-2019, 05:15 PM | #10 |
Might not harm the metal, true. But what's a strong solvent going to do to the plastic knob?
11-24-2019, 05:26 PM | #11 |
Point taken, but, if the knob is being sacrificed anyway, . . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
11-24-2019, 05:36 PM | #12 |
Knock yourself out then, if it's cheaper to do than just buying new Deluxe knobs.
11-24-2019, 07:55 PM | #13 |
You can't buy a new throttle knob. That's the thing. You got it, the knob is being trashed for the trim anyway. Plus... I'd almost bet that plastic could take it. Seems so hard and tough. Only one way to find out, right?
11-24-2019, 10:39 PM | #14 |
BlahBlahBlah
For some reason I feel like Randy500 did a knob conversion … Maybe?
11-25-2019, 12:24 PM | #15 |
Those have three clips that extend down that plastic is molded around, not glued on. I have an extra one if you want it.
11-25-2019, 03:33 PM | #16 |
Carpe manana
Atog, yes I would. Let me know what you need for it. Thanks a lot. Pete
11-27-2019, 08:50 AM | #17 |
I would often think if the inserts themself can be made and used on the base knobs, seems like that from the factory.
11-27-2019, 11:37 AM | #18 |
Carpe manana
That wouldn’t be a bad idea. Inserts that can be glued to base knobs. I’ll post up a pic of an insert when in hand.
11-27-2019, 12:28 PM | #19 |
Pete, Maybe you can see the little metal 'ear' that's exposed on this broken knob.
It holds the shiny center onto the knob along with a couple more, like atog said. You can have this one as a freebie if you have any luck fixing the other one. LMK
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
11-27-2019, 12:32 PM | #20 |
Carpe manana
Larry thanks a bunch for the offer. Member Atog was generous and offered an insert to me. I’ll let you know if I end up needing another but think I’m set for the time being. Should be fun project to add this.
11-29-2019, 11:26 PM | #21 |
Pete,
Post pics. I have several NOS standard throttle control knobs I thought about making some deluxe. |
11-30-2019, 10:44 AM | #22 |
Carpe manana
You bet John. I don’t have the insert yet. Will update. I’m wondering if the legs on the trim could be ground down then the trim merely glued in place.
