Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-23-2019, 06:49 PM   #1
dmjlambert
dmjlambert's Avatar
Used Craftsman drill and bits
I went to the flea market today and found this drill. I wonder if any of you guys recognize what sort of bits these are that were in the handle. I don't believe I've seen any like this, they have a straight slot instead of the spiral I am accustomed to seeing on drill bits.
dmjlambert is offline   Reply With Quote
Old 11-23-2019, 08:47 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Used Craftsman drill and bits
Those drills with that drill holder was used for Bronze, Brass and Aluminum.
Bronze and brass tend to pull a regular twist drill into the work-piece quicker than a person can control. Those straight flute drills don't make that long stringy chip.
A trick to use a twist drill on non-ferrous material is to dull the sharp edges a little so it won't pull in as bad.
The early bird gets the worm,
85 Chevy K-20
Old 11-23-2019, 11:57 PM   #3
dmjlambert
dmjlambert's Avatar
Excellent, thanks for that info, I like to learn stuff like that.
drill, drill bits
