Old 11-25-2019, 10:13 AM   #1
Dachshund
Undercoat Removal
What is the "easiest" way to remove this stuff? I have a spot about 1' x 18" on the back side of an inner fender that I need to remove. The stuff LIKES where it is. Might have to heat it up or something....Any ideas?
Dachshund is offline   Reply With Quote
Old 11-25-2019, 10:34 AM   #2
Driver_WT
Driver_WT's Avatar
Re: Undercoat Removal
I use a wire wheel on my angle grinder. Pretty much takes off anything.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 11-25-2019, 11:35 AM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
If you dont have paint to worry about, then small torch can heat it up where it can be scraped easily...
If it's already painted then the wire wheel may be best
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-25-2019, 05:18 PM   #4
MiraclePieCo
MiraclePieCo's Avatar
I've had excellent results soaking it thoroughly with WD-40 for a few days. The stuff penetrates behind the undercoat and loosens it.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-26-2019, 08:32 AM   #5
Dachshund
ok, Thanks! I ended up heating it with a torch and scraping it off. The stuff was nasty thick, and the wire wheel made too much dust....
