After tune up, hard to start
Hey folks!
I'm teaching my 10 year old how to be a gear head squares junky. So far so good! 1973 Suburban 350/350. GM HEI ignition (likely from an 80s era truck). Had the truck about 5 years and never did any tune up on it. It has always been very easy to start when warm. Cold (after a couple days sitting) it would do the typical "crank, crank, crank - where's my gas - crank, vroom" Finally started to miss, and was not running on all cylinders (all the time), so we replaced * plugs * Plug Wires * Distributor Cap * Rotor After my "tune up" it's been not wanting to start when warm, and requires several seconds of cranking. So I've been fiddling with the timing a bit. Assuming that when you do cap and rotor you have to reset the timing I unplug the vacuum hose from the distributor vacuum advance to do this. Warm it up, then set "initial timing" (at idle). Originally I put it at about 14 degrees BTDC, (hard to start) and today I bumped it down to 10 degrees. What should this be at, and will small differences (say going to 11!) make a big difference? Thanks! I really want this thing to fire right back up again! |
| Bookmarks |
