11-30-2019, 06:12 PM | #1 |
Welder series four link
I did a ton of research before ordering, and never saw or thought of this, stuff is good quality , welds are beautiful, so , i ordered a welded set...here is the issue, if you are building a truck where the frame is wider at the rear, do not get the tabs on the frame mounts welded, ill explain but the pic should do it, as it is, ill have to angle cut my front frame mounts 1/2”.....if the tabs were not welded then it would be simple to square them up,
12-03-2019, 01:48 PM | #2 |
Re: Welder series four link
Not sure what your getting at but the bracket you have sitting on the housing looks like a lower bracket. Those holes are usually for the shocks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
