Old 12-05-2003, 03:51 PM   #1
Injected68LS1
Injected68LS1's Avatar
What year did they change to the wider rear axles?
I curious when they changed from the shorter rear end(67-68) to the wider rear end (69?-72?)
I have the 68 stock rear end.
Is there a wider rear end that will still have the trailing arm mounts?
thanks
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-05-2003, 03:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some where in the 1970 model they went to a wider rear. That would still be a 6 lug. In 71, they went to 5 lug.
So a mid 70 - 72 would be the width you're looking for and maintian the coil set up.
Old 12-05-2003, 04:00 PM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I'm not sure on this but I think it is 64-69 and then 70-72. Don't quote me on that but I think 70 was the first year of the wider axle.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 12-05-2003, 06:25 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Sometime during the 1970 model year..some are narrow and some are wide. Mine happened to be wide
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-05-2003, 06:34 PM   #5
Bram
Broke
Bram's Avatar
I've wondered the same thing, because my 72 3/4 ton 4x4 had a narrow rear end.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 12-05-2003, 06:57 PM   #6
Injected68LS1
So is it possible to have a wider, five-lug, coil-spring rear-end?
Also, does anybody know how much wider they are from flange-to-flange?
thanks
Old 12-05-2003, 07:45 PM   #7
krue
Designated A-hole!
krue's Avatar
1.5 inches is what I have heard.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-05-2003, 09:17 PM   #8
1971 Cheyenne
1971 Cheyenne's Avatar
thanks
Yes, you will be looking for a 71-72 1/2 ton coil sprung rear end.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 12-05-2003, 11:44 PM   #9
casey
casey's Avatar
Bram
I have the narrowed rear too on my 71 1/2ton 4x4, not quite sure why they did that, for tracking reasons maybe, I do think it looks silly with a nice stance on the front and the narrowed rear, I was thinking of wheel adators for the back like 1 1/4" on each side to even it out, If I remember correctly I think the back is 2 1/2" narrower over all
casey is offline   Reply With Quote
Old 12-06-2003, 12:54 AM   #10
cableguy0
casey do not use wheel spacers they are unsafe they put the whole load on the wheel studs instead of on the hub where it belongs.. you could try a different backspacing on the wheels instead
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-06-2003, 04:16 AM   #11
casey
casey's Avatar
I agree it will put alittle more load on the bearings, but I don't 4x4 or carry any load, and if you think about it what would be the differance between an adaptor moving the wheel out 1" or a back space on the rim moving the wheel out 1", then you can't rotate the tires from front to back, what do you think?
Old 12-06-2003, 05:37 AM   #12
Injected68LS1
Your right. You will impose the same load on the bearing no matter how you space out your wheel. It will change the load on your studs. Can't say if it would be bad. There's only one way to find out.
