![]() Join Date: Jan 2018
Leak Down Kick Panel - Restored Truck
I am still working out all the small bugs on my truck and I took it on a 500 mile roadtrip in the rain and realized I have some leaks. The first is near the top of the DS windshield which I will put some silicone between window frame and new gasket. The other is my PS floorboard was soaked but I didn't see any rain coming in. There is a trail of water residue behind my kickpanel vent so it appears to be coming from above this. Could this be from the lower corner of the windshield, running down the kickpanel inside dash?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Re: Leak Down Kick Panel - Restored Truck
Could be but might be a seem on the firewall where the sealer has cracked and fallen off or rust through where you can't see. Depends on how far into it you got on the restoration. Some others from the rust belt can chime in that have been down that route before.
68' with no bells or whistles unless I add'em. |
Go Pack Go!
I've seen "restored" trucks have so much rust under the cowl that went down to the fresh air duct work. Leaked on floor real bad too.
Could be...I didn't cut the cowl apart to look just a clean out and POR-15. I only mention restored as it has all new rubber, glass, roof seam sealer, and VA installed which could all be causing leaks in that area.
I left the glovebox liner out so I could check for leaks on the passenger side with out having to lie on your back.
71 C-20 07 Magnum RT AWD |
![]() Join Date: May 2010
We had a new '69 Olds that had the same problem. I applied red food color with a small amount of water to various locations starting at the lowest level then upward until I saw red water inside the car. The water was coming down the A pillar caused by a gap in the roof sealer in the gutter above the A pillar.
![]() Join Date: Feb 2019
Dont use Silicone to seal a windshield leak.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
What should I use instead?
Post Whore
![]() Join Date: Feb 2016
It is likely that you have just the leak from the seal. The water is leaking out from under the window seal where it meets the dash as well as the driver's side. The dash has several weep holes in it to let condensation drain to the floor. My Burban is in the shop right now getting the windshield resealed to stop this. Not the best picture but I've tried to indicate the weep holes. The water on the dash on mine was almost invisible as the water exited the seal less than 1/2" from the weep hole.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Post Whore
![]() Join Date: Jul 2018
I had a similar leak. Turned out to be a couple of issues. First the overlapping metal that make up the bottom side of the airbox was not welded properly. In fact the spot welds never took and left a huge gap of about 1/8” that was just filled with seam sealer. That area started rusting and combined with the dried out seam sealer in the same area of the rain gutter created a big hole and I had to remove the inner cowl and a 3”x4” area just above the glove box liner. Still haven’t had time to complete the repair, but that leak and horrible seam construction created a similar leak on mine.
1971 Custom/10 - 350/3 speed, Orange/White roof |
