Old 12-03-2019, 01:35 PM   #1
mygmctruck1
Wanted 2 rear brake drums 68 K1500
Ok , looking for 2 rear brake drums 68 K1500 , I am ok with turning them for clean up only . If you have 2 decent drums . let e know.
mygmctruck1 is offline   Reply With Quote
Old 12-03-2019, 04:08 PM   #2
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: Wanted 2 rear brake drums 68 K1500
https://www.autozone.com/brakes-and-...8106/21774_0_0
https://www.napaonline.com/en/search...onEnabled=true
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-03-2019, 04:10 PM   #3
68panelman
68panelman's Avatar
I believe these are available new. I do know my brakes are the same between my K/5 and my 67 2wd, drums and hardware linings ect
68panelman is offline   Reply With Quote
Old 12-03-2019, 04:11 PM   #4
68panelman
68panelman's Avatar
Same time as Richard, well, almost he posted as I slowly two fingered typed
Old 12-03-2019, 06:07 PM   #5
cbeerman
Good luck I wound up going with the jeep drums
http://67-72chevytrucks.com/vboard/s...d.php?t=614719
cbeerman is offline   Reply With Quote
Old 12-04-2019, 10:23 AM   #6
painterljp
Auto zones drums wont fit our gmc. Ours has the larger studs and they are different. We had good luck at rock auto. Bought two new ones then they went on clearance and we bought two more. No one has them. No we wont sell the extra ones but if yours has larger studs can send you part number when I get home. Ours is a 68 gmc 1500 2 wheel drive.
painterljp is offline   Reply With Quote
Old 12-04-2019, 10:47 AM   #7
68panelman
68panelman's Avatar
Original poster needs to reply and tell us what rear he has, a picture would be fantastic.
Old 12-04-2019, 03:52 PM   #8
mygmctruck1
A pic , what good will that do ? The rear drums are different size than the fronts. deeper but still 2 " brake shoe. Supposedly auto value can get them , I'm going to wait for awhile before I order anything new.
Old 12-04-2019, 03:53 PM   #9
mygmctruck1
the 68 K1500 have 7/16 studs and 6 hole. The drum is deeper than the front drum but still uses the 2' shoe.
Old 12-04-2019, 03:57 PM   #10
68panelman
68panelman's Avatar
Like they say a picture is worth a thousand words? Hahaha
Is it original to the truck?, A Dana 44,60?, GM 12 bolt?
Old 12-04-2019, 05:20 PM   #11
cbeerman
It should be a dana44, besides looking at the pumpkin the emergency brake cables bolt to the backing plates whereas the 12 bolts have a push in clip.
Old 12-04-2019, 06:02 PM   #12
painterljp
Yes what he said. Ours is 6 hole. Dana 44 - 3.54 ratio. 68 gmc leaf springs truck. Larger studs than our 71 chevy.
Old 12-04-2019, 07:22 PM   #13
mygmctruck1
I should have said why I need brake drums , mine were fine except I had to have the lug hole enlarged because of new larger studs.
The mechanic was supposed to enlarge them by just 1/8” larger than the new stud.
He got carried away and now there 1/4” larger . I know there a reason lug holes are not over sized , so the drum won’t rotate to much when brakes are applied and ripping the shoes off the pins .
I’m sure that’s the reason for lug holes not being to big ?
this Is correct isn’t it ?
