12-05-2019, 11:47 AM | #1 |
Going back to OE Steering Wheel
After searching, I see many threads on going from an OE steering wheel to an Aftermarket but not the other way around.
Can anyone tell me what is needed to replace the old grant wheel in my truck with an original steering wheel? Do I need a new OE steering wheel mounting kit? Thanks for any insight.
Jim 1972 K20 Cheyenne- 350/350/205 1972 K20 Cheyenne - 350/SM465/205 |
12-05-2019, 12:26 PM | #2 |
Old member
Re: Going back to OE Steering Wheel
If you buy a original type steering wheel no. The wheel has the mount made into it. You will need the horn cap and the parts that go inside the wheel to make the horn work depending on what year steering wheel you end up with. My pictures are of a OE 70's model steering wheel.
12-05-2019, 12:57 PM | #3 |
Thank you for answering my question and providing me the photos! I’m glad it’s that’s simple.
12-05-2019, 01:02 PM | #4 | |
Old member
Getting the right parts is sometimes the hardest part. Putting them in correctly is also important. There are links to how they go in. Just use the search button.
12-05-2019, 03:59 PM | #5 |
Jim,
I put an OEM 1967 steering wheel into my 71 C2500, and I really like it. The fawn color even matches my steering column and glove box cover. The horn hardware also fit right in. Good luck. JP
1971 GMC C2500 LWB (My first truck.) |
12-05-2019, 05:00 PM | #6 |
Looks awesome. IMO, you can’t beat the look of a period correct Chevrolet wheel in these trucks.
12-05-2019, 05:55 PM | #7 |
Junior Member
I agree - the look of the OE wheel is best in our trucks. If you want the OE look but would still like the extra leg room of an aftermarket wheel, Brothers has a new 15" OE replica wheel that works well.
Ken |
12-05-2019, 06:32 PM | #8 |
Carpe manana
Andy is that the seldom-seen gasket on the horn cap?
Baime - greetings from next door in Eau Claire.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-05-2019, 08:04 PM | #9 | |
Old member
There are other wheels out there that look good in our trucks at least I think so any way. Here are a few of mine. 67 Chevelle wheel in my 71 C10. Then the old Corvette wheel that I made the horn cap for my 67 Ramp truck. The 3 spoke wood wheel going in the 68 with factory tilt. I'll be making a 1 off horn cap for it as well. Then 1 of the 2 spoke wooden wheels I have. All the horns work like they are suppose to also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-05-2019 at 08:35 PM. |
12-05-2019, 09:36 PM | #10 |
The Older Generation
Here are the horn parts you will need. There are two different metal cups. The '67 & '68 is 1" tall and the '69-'72 is 3/4" tall. 2nd pic posted by leddzepp. LockDoc
12-05-2019, 11:59 PM | #11 | |
Funny stuff when Laurel & Hardy or the 3 Stooges do it, not so funny when it's _you_ and you're downtown. I stuck it back on and white-knuckled my way home. [I think they should be outlawed.] But I was lucky, the PO had included the OEM wheel with the '71 Jimmy, when I bought it. I put the stock 17" wheel back on and, for once, it handled better. Pulled thru turns perfectly, and pointed where I wanted it without a second look. The Grant wheel was twitchy and had to be reclocked a couple times. With manual steering, a small diameter wheel is a lot of extra work just making turns. Also the larger diameter wheel gives you a lot more leverage when the P/S fails. Grant wheels are for kids. If you [or the PO] lost the original parts, The Car and Truck shops has a lot of the harder-to-find small parts. I hear the repop steering wheels are not that good. Better to acquire an original wheel and repair it if needed.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-06-2019 at 12:06 AM. |
12-06-2019, 11:35 AM | #12 |
That sounds like an installation problem, not a steering wheel problem I laugh cause I've done that to myself once. Wasn't paying attention and didn't put the nut back on before a long test drive. That made for a fun ride
72 C10 lwb fleetside -stock 350/350 combo |
12-06-2019, 11:37 AM | #13 | |
I would have left the original steering wheel in my truck, but it was all melted near the steering column. I'm assuming from the sun. I really dislike the looks of the modern non-OEM looking steering wheels. Everyone's taste is different, and I think that makes it more fun. My truck is a 3/4 long bed fleet side GMC. A lot of people don't want that version of these trucks. I call it a "truck truck". It isn't trying to be sports car. I just really like it, and it is usable. Take care, JP
12-06-2019, 02:18 PM | #14 |
I also put a 67 steeing wheel in My 71 gmc. Fit just fine. Although it fawn and it should be black. My original looked like it whent through a fire. That was the firest thing I ever did to my gmc.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
12-06-2019, 02:55 PM | #15 |
Thanks for the photos! I will not be using a horn in the truck and don’t care to hook it up. Will I still need those horn parts for the structural integrity of the wheel?
12-06-2019, 03:43 PM | #16 | |
Old member
NO! It's not a good idea not to have the horn working though. It's not that hard to do. The wiring is already there in the column are it should be.
12-06-2019, 04:42 PM | #17 | |
Mike Posted via Mobile Device |
12-06-2019, 06:56 PM | #18 | ||
Actually yes, the cancelling cam (the piece with the white tower on it) holds the top bearing in place. It may be under the aftermarket wheel. LockDoc
12-07-2019, 09:31 AM | #19 |
Got it! Thanks for answering my questions!
12-07-2019, 10:23 AM | #20 |
Don't know about your state, but the horn is necessary pass inspection in MO.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
12-07-2019, 11:31 AM | #21 |
I've always liked the look & feel of these Impala wheels.... '59-'60. Same diameter as stock(BIG) and fit the column nicely with no adapter.
PS: good idea to have a working horn... bad feeling as somebody looking the wrong way backs into my truck.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
12-08-2019, 02:02 AM | #22 | |
Yeah, it's funny because I'm alive, and I can take a joke. But the small wheel was a drag.
12-08-2019, 02:14 AM | #23 | |
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-08-2019 at 11:58 AM. |
12-08-2019, 09:09 AM | #24 |
Fortunately no inspection on this side of the state.
10-08-2020, 11:11 AM | #25 |
So, I know this is an older thread, but I'm going through the same thing right now... even had started a thread asking questions just like this. And yes, I did use the search function previously, but didn't find this thread.
Anyway, I want to hook up my horn, but when I see the pictures the OP put up, I don't have the black wire that is shown. One of the previous owners of my truck, mounted a push button under the dash to use for the horn (which doesn't work). I'd like to get rid of that, and hook up the horn the way it should be. Does anyone know which wires I need to be looking for? EDIT - I had the exact same Grant wheel as the OP in my truck. I'm putting in an '80's Chevy wheel in it's place.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
