12-05-2019, 05:01 PM | #1 |
Carpet getting installed
Got the carpet seat in the truck little more work to with it
12-05-2019, 09:42 PM | #2 |
Re: Carpet getting installed
looks nice
12-05-2019, 10:55 PM | #3 |
That's sharp man!
12-06-2019, 05:39 AM | #4 |
Good job.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
12-06-2019, 08:57 PM | #5 |
Nice truck!
12-06-2019, 11:33 PM | #6 |
12-07-2019, 01:18 PM | #7 |
Looks great, Hard to drive without a seat though...
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
12-08-2019, 06:57 AM | #8 |
New black carpet in mine, too. The light blue carpet added to just too much blue overall..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
12-08-2019, 10:03 AM | #9 |
Not to sound silly, but what is the best way to install seat? Do you cut the carpet out around the base of the seat track, or is it best to glue carpet down, then punch holes through for the bolts. I know that trying to drill them may cause carpet to unravel. What are some of the ways that you have had the best luck with?
12-08-2019, 10:34 AM | #10 |
This my frist build I really dont know how I'm going to do it
12-08-2019, 12:29 PM | #11 |
Search for the Treads on it. I’ve heard different techniques from a punch, to melting the holes in with a Soldering Iron. I’m gonna follow this though, because I’m putting a new carpet in mine sometime this year
12-08-2019, 04:35 PM | #12 |
SUPER......and the carpet is nice too......I located the holes in the carpet with an awl..can be done from underneath the truck push up thru the reinforced mounting nuts.....mark with tape and or sharpie....use 3/8" punch to cut clean hole in carpet.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
12-08-2019, 05:38 PM | #13 |
I also marked using an awl from underneath, but I then used a 3/4" hole saw slowly IN REVERSE to drill while supporting the carpet above the floor.. If I recall, this method was shown in a video on the Stock Interiors website. Punch sounds like a good idea.
12-08-2019, 08:23 PM | #14 |
Forgot to mention punch can be used without hammer, if it is sharp a couple of twists while pushing down will make a nice clean cut. You can also sharpen almost any tube if you don't have a punch.
12-09-2019, 03:50 PM | #15 |
Thanks for the replies. One of my buddies use to work at Sears in the automotive section back in the sixties. They use to install a lot of seat belts. He said when ever they installed a set they used a punch and a hammer, it would go thru the carpet and the floor board, then install a big washer underneath and tighten. I could see where a punch would work.
12-10-2019, 04:13 AM | #16 |
I did the soldering iron trick on my install. Ruined the soldering iron, but it worked great. Also cauterized the holes so there was no unraveling or fraying etc.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
12-11-2019, 06:14 PM | #17 |
What's the best way to do the carpet for gas tank
12-12-2019, 03:24 PM | #18 |
When I had the carpet installed in my truck, My upholstery guy recommended strongly against covering the gas tank. Can't remember exactly why, maybe experts here can tell pros and cons of covering the gas tank.
12-12-2019, 04:18 PM | #19 |
Read this. Especially the last couple pages.
https://67-72chevytrucks.com/vboard/...d.php?t=268050 |
