Old 12-06-2019, 12:30 AM   #1
Ilike 72"s
1967 bench seat
I just took a bench seat out of a 67 c10. I need to replace the foam and cover.
I'm putting it into a 72 k10 that is missing the seat.
Is the seat lower and upper foam the same or different than the 72's? I assume the 72 cover with correct pattern will fit. Am I thinking right?
Ilike 72"s is offline   Reply With Quote
Old 12-06-2019, 12:42 AM   #2
Astro-Balls
Astro-Balls's Avatar
Re: 1967 bench seat
There were several options in foam padding/Springs..
67-72 Chevy truck cushions came in 5 models
6″ thick molded foam bottom with molded back. (#CT6972)
6″ molded foam bottom/coil spring back with thin pad.
Coil spring bottom with thin pad/molded foam back.
Coil spring bottom and back. Thin pad on both.
Some Canadian truck seats have been reported to be 1-2″ longer than American seat frames.
http://www.americancushionind.net/pr...-gmc-suburban/
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 12-06-2019, 12:52 AM   #3
Ilike 72"s
Re: 1967 bench seat
Figured it somehow wouldn't be as easy as ordering for a 72 bench. It also has the back that hinges forward. That may also be an issue. I may look for another donor seat. I'll be looking this seat over this weekend to see what springs and foam, then decide.
Dennis
Old 12-06-2019, 01:04 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1967 bench seat
Dennis
The covers for the folding seat are made different. You would have to get the cover for the '67 seat.
LockDoc
Leon
Old 12-06-2019, 11:33 AM   #5
landarts
landarts
Re: 1967 bench seat
LockDoc
LockDoc can you explain what the difference is on the folding seat - seat cover? Or do you know where I can see a comparison possibly?
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-06-2019, 12:19 PM   #6
LockDoc
LockDoc's Avatar
Re: 1967 bench seat
On the folding seat the metal of the hinge has to be exposed so it will fold forward. On the fixed seat the upholstery covers the metal in that area. I'm sure a good upholstery shop could modify the later cover to work with the the earlier seat, dunno for sure. Grumpy Old Man could probably answer that question if you would shoot him a PM.
LockDoc
Leon
Old 12-06-2019, 03:32 PM   #7
landarts
landarts
Re: 1967 bench seat
LockDoc, thanks for the explanation that makes sense.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
