Old 12-07-2019, 12:13 PM   #1
domano 68
Rear Differential Oil
Going to put a new gasket on my rear diff on my 71 C10 307 V8 Automatic. Leaking pretty bad and I don't know the history so I figured I'd fresh'n it up. What are the specs on the gear oil, 75W-90, ... etc? Non synthetic I assume.
Service manual says GL5, not sure what that translates to in a 75w, 80w, .... Also, how many quarts? Any special additives?
Example: Ok to use this?
https://shop.advanceautoparts.com/p/...lvoline+80w-90
Thanks in advance!
1971 C10 127 in wheelbase
Model Number-CS10934
Body Type & Seating-Fleetside 8 ft.
Original Factory Price-$2,854
Shipping Weight-3,605 lbs
Total Production-206,313
domano 68 is offline   Reply With Quote
Old 12-07-2019, 12:21 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Rear Differential Oil
Get the gear oil gasket maker for sure to have no leaks. This stuff works great and is much better than the normal stuff. I use the Valvoline 80-90 gear lube in all of mine.
https://www.autoserviceprofessional....desktop-view=1
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-07-2019, 12:39 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Andy beat me to the punch with that Permatex. It's called Gasket Maker but I smear a thin coating on both sides of a gasket. No leaks, great stuff, made to use with gear oil.
I typically use Mobil-1 75W-90 synthetic, but any good gear oil will work fine. If you have an open diff you don't need any additives.
I'd get 3 quarts and you'll probably have some left over.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-07-2019, 12:44 PM   #4
domano 68
Thanks for the responses, just what I was looking for!
Not sure if open diff or not. It is a 12 bolt though.
The brake line is attached to one of the bolts. It appears to be very rigid. I assume it will easily move out of the way once I remove the bolt that attaches it to the diff cover. Not much space with the panhard bar being close also, but I assume just enough room to get cover off and back on. Thanks again!
Old 12-07-2019, 01:38 PM   #5
truckster
truckster's Avatar
There will be enough room once you take the bolts out.
I agree with the recommendations so far, but if you discover it's a positraction, I like to use Royal Purple in those. No friction modifiers are needed with Royal Purple.
While you're in there, snap a pic of the numbers on the ring gear. At some point you might want to know for sure what your rear ratio is, and that will tell you.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 12-07-2019, 03:21 PM   #6
Wrenchbender Ret
The GL 5 is not the viscosity. It is a anti friction rating. You must use gl5 in differentials.
Practically all gear lubes are rated for GL 5. If your seals are old you might use 85w140 in the rear end unless you are using it in extreme cold.
If it is a Posi-trac you need to put an additive in it.
George
Wrenchbender Ret is offline   Reply With Quote
Old 12-07-2019, 09:01 PM   #7
ManNamedJed
I put 'Lubelocker' gaskets on mine. No sealant needed and you can reuse them if you have to pull the cover again. No leaks ever.
ManNamedJed is offline   Reply With Quote
Old 12-07-2019, 10:15 PM   #8
CS1972
CS1972's Avatar
I used LubeLocker for both my front Dana 44 and the rear 12 bolt and NO LEAKS ! Quite honestly it's my first time not using the typical gasket / sealer and after doing so I don't know why anyone would mess with smearing it all on equally and dealing with the mess. Sure the Lubelockers are more, but remember you don't have to buy the sealer.
Take pics of your ring gear so you'll know what ratio you have FOR SURE.
I used Mobil1 75W-90 Synthetic Gear Lubricant LS which will work for BOTH limited slip and non limited slip rear ends.
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 12-07-2019, 11:13 PM   #9
53burb
53burb's Avatar
I used the Right Stuff by Permatex on my rear diff on my Ram....no gasket...worked great!!
I learned about it from this site....surprised no one has mentioned it yet....
https://www.amazon.com/Permatex-3369...a-448741432246
53burb is offline   Reply With Quote
Old 12-08-2019, 12:55 AM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Lubelockers are new to me but sound intriguing. Summit lists 43 different gaskets, unfortunately none to fit my K20's rear diff.
- Mike -
RIP El Jay
Old 12-08-2019, 02:24 AM   #11
57taskforce
All about them K’s
57taskforce's Avatar
Same here I get the big aerosol can of the right stuff for jobs like this. Never had a leak using it and it cleans up pretty easily when it’s time to change the oil again. In use 80w90 for oil.
Tyler
57taskforce is online now   Reply With Quote
Old 12-08-2019, 08:50 AM   #12
I use Purple Power, too. I have a posi rear and also use it up front w/o posi. No harm in using better than called for.
Old 12-08-2019, 10:25 AM   #13
Bigdav160
Bigdav160's Avatar
George
Just for clarity, GL5 is a SAE test sequence that certifies a fluid to meet a standard.
It is normal for an older standard be replaced by a newer standard.
But there is nothing to prevent an oil blender from marketing an lubricant without pursuing the expense of certification.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-08-2019, 09:45 PM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
Make sure to use a thread sealer on the bolts that pass thru the housing into the oil or it will
leak in those areas. I forget which two they are but you can look at them and tell.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-09-2019, 10:29 AM   #15
Happy_dan
Happy_dan's Avatar
If you have a posi and you want to use Royal Purple there is one that end in LS, that means limited slip. I use that in my ZL1 Camaro and rear is nice and quiet.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
