Old 12-08-2019, 02:39 AM   #1
Isaiah92260
Isaiah92260's Avatar
Won’t start. First time my truck has ever defeated me.
So today my carburetor was puking gas out from all over the place. I figured because the jets got clogged up from dirty gas. I probably havnt changed my gas filter since September. So I put in a new filter. She still won’t start.
So then I cracked up the carburetor and cleaned out the jet and the insides good. Still won’t start. Then I went as far as sucked out gas from the manifold with a siphon thinking that the motor got flooded. Got not start still.
Then I found the #4 and #6 spark plugs were wet.
Then I tried sucking out anything from the spark plug holes but no gas, so then I installed new spark plugs, AND STILL WONT START. I even tried spraying starting fluid and nothing. I have a 1961 235 that I’ve been driving around with no problems before. The carburetor is a single B Rochester. If anyone knows what might be wrong please help... I have a Petronix ignition upgrade and a new coil that are at least 4 months old, so I can’t believe it would be that..
Isaiah92260 is offline   Reply With Quote
Old 12-08-2019, 09:35 AM   #2
nsb29
nsb29's Avatar
Re: Won’t start. First time my truck has ever defeated me.
If you’re carb was dumping gas the float was stuck open, pull the plugs and let it dry out, you can turn the motor over to help if you have air to blow it out. I would clean your plugs before you put them back. If it still doesn’t start check to see if you’re getting gas the float can stick closed as well
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-08-2019, 10:00 AM   #3
sstock
sstock's Avatar
Seen a lot of Carburetors get the blame for a failing pertronix, you didnt happen to leave the key on and the engine off lately did you?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 12-08-2019, 12:31 PM   #4
cgrocen
My money is on a faulty Pertronix. My buddy here in town had a Pertronix fail on his Chevy truck. Check for spark. You may not have spark. Even with the starting fluid, you should have at least got something, even a 2 second sputter.
cgrocen is offline   Reply With Quote
Old 12-08-2019, 01:19 PM   #5
bhap
bhap's Avatar
NSB29 has it right. Float stuck allows gas to flood engine. Assuming this is a stock engine with mechanical fuel pump, the longer you crank, the more fuel dumps into engine. Time for a rebuild. Buy a kit, keep track of how it comes apart and it should be an easy fix.
bhap is offline   Reply With Quote
Old 12-08-2019, 04:26 PM   #6
vince1
I had the 250 flooding and filling the crankcase full of fuel because a new fuel cap would vent in and not out. With the changing of weather from hot to cold a lot of pressure would build in the tank, although it would still start.
With flooding it sounds like you may have a compromised float needle but I agree that the first thing to check for is spark.
Just another your/you're link https://www.youtube.com/watch?v=srssajH4NMk
vince1 is offline   Reply With Quote
Old 12-12-2019, 12:00 AM   #7
Isaiah92260
Hey fellas thank you for your replies. I have no idea still why my carburetor was flooding like it did, i actually bought this carburetor as an original unit that was professionally rebuilt by a local shop near me in El Monte, CA. I did like what you said @ nsb29 and I took part the carburetor and cleaned it out really good, I let the block air out.
Still didn’t start.
So finally I checked for spark and like you guys mentioned @ sstock & @ cgrocen I checked out the cool first and I was getting no power. I guess the petronix May have fried our my old coil? I’m pretty sure it was a high amp coil too
It runs good now.
On to the next project..
Old 12-12-2019, 02:19 PM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Pertronix needs full 12 volts but your coil typically does not. That is why GM had a resistor wire and other brands used a firewall mounted resistor.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-12-2019, 09:28 PM   #9
Isaiah92260
Oh I see. How do I add a resistor for reassurance ?
Old 12-12-2019, 11:40 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If your keeping the pertronix you won’t need the resistor
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-13-2019, 01:33 AM   #11
franken
I'll guess it's the ignition, but. Don't check for spark.
Pull the carb and plugs. Put the plugs back in. Connect them to plug wires. Crank and shoot B12 down the manifold.
Check for spark.
Sorry
franken is offline   Reply With Quote
