Old 12-08-2019, 03:37 PM   #1
prodjay10
ecm question...
Would it be possible to buy an ecm from a car of the same year and have all the info overwritten for a truck tune?
Donor vehicle for swap: 2002 suburban 5.3 with 4l60e
I'm thinking of picking up a spare ECM and have it tuned with the suburban's data. I can get a really cheap one off a 2002 v6 car shipped for $30.
prodjay10 is offline   Reply With Quote
Old 12-08-2019, 04:46 PM   #2
Gregski
Post Whore
Gregski's Avatar
Re: ecm question...
short answer is yes for example the 12200411 PCM module was widely used on V6 and V8 vehicles, once you get a box you can FLASH it and even change the VIN number on it, do you know what Service No ie Part Number you are buying?
One gotcha would be is it the Red and Blue connector era (drive by cable) or the Green and Blue connector era (ie drive by wire). 2002 sounds like Red and Blue so still the drive by cable. So do you have a Red and Blue wiring harness already?
Gregski is offline   Reply With Quote
Old 12-08-2019, 05:56 PM   #3
prodjay10
Re: ecm question...
2002-2005 Chevrolet Impala Monte Carlo
12583827
My current setup is dbc.
Old 12-08-2019, 11:47 PM   #4
kipps
Re: ecm question...
I'm hoping to do something similar. I've got a 2010 e38 that I intend to flash from a truck to a camaro. Since the part no. is the same, I'm reasonably confident this will work well. The second part of the equation is that intend to go back into the Camaro tune, and change all parameters back to the original truck engine. Again, I think it will work, but I'm less confident. This should give me the closest thing to a factory gen iv truck engine with a manual transmission.
I hope to do it with only one hptuners license purchase -- for the camaro tune. I can read my original vortec tune without licensing it.
Again, this is all on gen iv. I assume you're working with a gen iii, which could be quite different.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 12-09-2019, 12:12 AM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: ecm question...
One license, not a chance. Each ecu needs a license aka 2 credits or more depending on application. Otherwise, obvuolsy this would be a loop hole for tuners...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
