![]() Join Date: Jun 2019
LS swaps?
Pretty new to the LS subject but I have been doing some research and notice a ton of people are finding these :S's and building them with incredible power.
Don't know if this forum is familiar with the Driveway engineer you tube video's, he does a great job showing what can be done with LS he pulls from the junkyard (some of his methods I do not agree with) but I love the fact he is sharing all of this information with the world. He claims you can easily make 400-600 rear wheel horse power on one of these 4.8, 5.3 or 6.0 motors, with a turbo. Anybody else enjoying his work? |
Re: LS swaps?
Hot rod magazine has great write ups on these.
Watch how much hp you build with a turbo. It gets really easy to get big hp, but you run into cylinder pressure issues. |
#3 | |
Post Whore
![]() Join Date: Aug 2014
Re: LS swaps?
& Yep on a short list I have: Sloppy Mechanics, Matt ChopperDoc181 CSSOB aka OverBooster, Alex LSxTuner Mega Mechatronics (if you want to make yourself feel stupid, ha ha) |
Re: LS swaps?
The engine is the easy and cheap part. The ECU (stock isn't the best option with boost anymore), fuel system, converter, and trans are the expensive pieces!
But I love my turbo C10. So much fun to drive and runs 11.50 on 10psi, and cruises so quiet you don't even know it's not stock. ![]()
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
Re: LS swaps?
Heh, almost in the tens in a pickup?
I always thought of LS motors as not making a lot of torque. Maybe I should do more reading... |
#6 | |
Re: LS swaps?
Its all in cam selection. Like most other small block chevys, they wont be the torque monster of a big block, but its not as if they are high strung like a 4 or 6cyl. Sure, valve angles that promote bigger power numbers might hurt low end torque, but I think 225+ft/lbs at the wheels from 2500rpm - 5000rpm isn't bad in a stock engine. To quote Steve Brule and David Freiburger, if this was a traditional 327, you'd be pretty excited about those numbers on a moderate build, except because of good flowing heads, the LS series engines do it stock. |
