Old 12-09-2019, 01:59 PM   #1
forestb
forestb's Avatar
60-62 rear lug nut bolts
I put some 1/8 wheel spacers on the rear of my truck and am a little worried about the length of the lug nut bolts. I was wondering if anyone knows if there is a longer version of the same bolt.
forestb is offline   Reply With Quote
Old 12-09-2019, 07:04 PM   #2
cookseyb
Re: 60-62 rear lug nut bolts
Bought some 2.250 from O'Rileys last Sunday they are 1/2-20 thread
cookseyb is offline   Reply With Quote
Old 12-09-2019, 07:07 PM   #3
forestb
forestb's Avatar
is 2.250 the part number?
Old 12-09-2019, 07:20 PM   #4
cookseyb
That is the length from the head face to the end of the stud ,stock is about 3/4 inch less
Old 12-09-2019, 07:37 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Does thread from the stud protrude through the nuts when they are installed? If so, you don't need longer studs.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-09-2019, 07:54 PM   #6
forestb
forestb's Avatar
no they don't. I have a standard type lug nut on there right now and the bolt is about 1/8 in from being flush with the nut
Old 12-09-2019, 08:04 PM   #7
cookseyb
You will need at least a full nut.. I got mine that long because I added disc brakes and thicker aluminum wheels. They have all lengths, just make sure they don't try and sell you metric threads..
Old 12-09-2019, 11:35 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
The rule of thumb is that there should be as much thread penetration as the diameter of the bolt, so yeah, you need longer studs. Should be easy to source at most auto parts stores.
~Steven
Simi Valley, CA
Old 12-09-2019, 11:54 PM   #9
slepysal
slepysal's Avatar
try a local wheel shop and see if they have "ET" style lug nuts . See if they will work on your rims
https://www.purefjcruiser.com/images/6850A-AP-ET.jpg
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
