Old 12-05-2003, 11:26 PM   #1
BLUE80GMC
Help Installing Hood Emblem
I got a new Hood Emblem on ebay. My hood has never had one. Anyone out there got any tips on where to drill or how to install?
BLUE80GMC is offline   Reply With Quote
Old 12-05-2003, 11:27 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i would think theres a set of holes through the inner part of the hood id look on the underside of the hood to see where it goes
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-05-2003, 11:30 PM   #3
ChevyGuyBC
can i see a picture of what you bought?
ChevyGuyBC is offline   Reply With Quote
Old 12-05-2003, 11:30 PM   #4
BLUE80GMC
I thought that too but the hood has an inner panel cant get to inner side without removing hood latch.
Old 12-05-2003, 11:40 PM   #5
BLUE80GMC
Hood Emblem
Here it is
Old 12-05-2003, 11:43 PM   #6
BLUE80GMC
Will have to drill 3 holes. 1 for the spring 1/2 inch or more & 2 for pins & clips 13/64. Not crazy about drilling holes. should i treat the holes.
Old 12-06-2003, 01:33 AM   #7
bigblock73
yeller
bigblock73's Avatar
I would definately paint the bare metal where the new holes are, you can also put some clear silicone on the bolt to help keep water out and keep the chance of water hitting bare metal to a minimum.
bigblock73 is offline   Reply With Quote
Old 12-06-2003, 02:48 AM   #8
Russell
Professional Grade
Russell's Avatar
There should be a hole in your underhood metal that you can stick a wrench through to install the hood emblem I would also treat those holes, and also stick silicone underneith to help seal the hood. I personally love the look of these emblems, your truck seems to be getting to look a lot like mine, lol! Now I just need to fix my rust and stuff...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-06-2003, 08:25 AM   #9
BLUE80GMC
There isn't a way to bolt it on . it has 2 pins on either end and the spring in the middle. I think you drill the holes then insert the pushin body clips then insert the emblem like side emblems.
Old 12-06-2003, 11:01 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
It uses "pal" nuts. They are stamped sheetmtal nuts that screw on to the pins. You can get them from GM or at the local hardware store.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-06-2003, 11:55 AM   #11
86SILVERADO
86SILVERADO's Avatar
You also need to very carefully thread the posts on the emblem or you will not be able to get the pal nuts on. I had to do this with the aftermarket hood letters that I bought for my 67 chev.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 12-06-2003, 12:14 PM   #12
BLUE80GMC
How to you thread the post? just xcrew on the pal nuts?
Old 12-06-2003, 12:15 PM   #13
BLUE80GMC
Or do you have to run a die on it?
Old 12-06-2003, 01:02 PM   #14
86SILVERADO
Yes you need to thread it with a die. Very carefully. Dont try to hog off too much. Just find the size that puts enough of a thread on it for the nut to have something to grab.
05 Duramax 3500
Old 12-06-2003, 01:52 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
They are also called "speed nuts". If you have the correct size, they should cut their own threads. They cut a very course thread as they go on, but you have to have the correct size. Here is what one looks like-
Old 12-06-2003, 01:59 PM   #16
BLUE80GMC
Thanks guys.
Old 12-08-2003, 01:48 PM   #17
KShortell
KShortell's Avatar
There also should be a plastic spacer that fits between the hood and the metal base to the ornament. This prevents the edges of the pot metal from grinding their way through the paint and causing rust.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 12-08-2003, 07:09 PM   #18
BLUE80GMC
Now you tell me. Already installed but I dont think this was the right one. I believe it was for 81-87 and mine is an 80. Is there a differrence in the hoods? Where can I get the spacer?
Old 12-08-2003, 10:40 PM   #19
86SILVERADO
Well I was going to tell you that I thought the truck would look nicer without it but I generally don't like to make those sort of comments. The hood style does change as you suspected. No going back now I guess.
05 Duramax 3500
Old 12-09-2003, 01:16 AM   #20
BLUE80GMC
I guess it will have to do for now. Until I find the correct ornament or get another hood. both of which take money.
