67 C10 Side mirror mounting measurements
Hi
Can somebody give me measurements on where to install the correct 67 side mirrors? My truck never had them ![]() Pic of said mirrors ![]() Thanks |
Re: 67 C10 Side mirror mounting measurements
Your pickup did have them at one point. You could dtake the door panel off and look up in ther and see if you can see the original holes. Hope there welded in and not just bondoed over. Although of ther just boondoed over it would make it easy to put the new ones on. Unless it's a new door skin.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
The Older Generation
Here's mine. Yours may have had them at one point. When you take the door panel off check the door to see if the mounting plates are laying in the bottom. Many people remove the mirrors from the outside and just let the mounting plates fall to the bottom of the door. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-10-2019 at 03:14 PM. |
| Bookmarks |
