Factory or Homemade?
I noticed while I taking apart the frame of my '65 C20, that the trailing arms have plates welded to the bottom and top of them. I am wondering if these plates were added for the 3/4 ton trailing arm trucks from the factory or did a PO add these to the truck?
1965 C20 LWB Flatbed Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=795718 Last edited by Mike1965; 12-12-2019 at 03:28 AM. |
![]() Join Date: Jan 2011
Re: Factory or Homemade?
I think my 66 C20 had em. Still not sure of the origin of the plates.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Moderator
![]() Join Date: Dec 2012
Factory plates on C20 and up.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Stiffening plates for the 3/4 ton, idk if factory tho
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
All C20's that I have seen had those from the factory to stiffen up the trailing arms. They also have a brace from the front of the trailing arm crossmember over to the frame rail, that is not present on a C10
Would these reinforcements be something worthwhile on a regular C10?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
![]() ![]() Join Date: Apr 2012
3881314 is the GM part number. C20 from 1960-1972 . Will also work on C10 as this is the later replacement part that was used to repair C10s
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
