Ideas for diagnosing random terrible noise?
I realize this is pretty vague, but maybe you've had a similar problem and have some ideas.....thanks in advance for any leads!
I have a new-to-me 1970 C20 350 with the the 4-speed granny trans. G80 rear axle. I don't use the granny so 2nd is first, 3rd is second, etc. There is an occasional metallic bang/jerk that happens upon acceleration. I am only driving around town at pretty low speeds, 20-40 max, so it's occurring in 2nd gear, sometimes in 3rd, and not in 4th that I can recall. Felt to me like it was in the driveline, I worried it was the diff going bad, or something in the transmission. Yikes $$$$. But today had a local crusty old transmission guy (the best kind!) test-drive the truck and when we felt it go BANG he said, "I don't know what that is, but rear ends are pretty consistent when they go bad, and your trans sounds normal for an old truck. I'm pretty sure it's not in your driveline, sounds like it's coming from up front." So I guess that's good, or at least less-expensive news, but not sure where to look. Some wild guesses: Motor mount? Frozen wheel bearing? Seized brake part? (The brakes only recently were restored to power assist but they seem to work fine, and the noise was there even when driving with Flintstones brakes.) What would you investigate next? |
![]() Join Date: Nov 2019
Re: Ideas for diagnosing random terrible noise?
Bad brakes or bearings will cause the vehicle to pull to the side that is causing the issue. Have you looked at the motor mounts? They usually will make a sound when taking off - the motor will lift, then when letting off the gas it will drop the motor down making a noise. Also, a bad driveshaft U joint will do basically the same thing. If you hit the gas and let off and hit the gas again and let off each time you should hear a clunking sound.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
I think Maverick is on the right track. If the truck was an automatic it would not be as apparent of a problem but with the stick trucks you would notice the mount more. I had an old truck that made a really annoying sound from the passenger side. After I divorced her the noise went away.
68' with no bells or whistles unless I add'em. |
Post Whore
![]() Join Date: Feb 2016
Does the truck have a limited slip (posi) rear end? They can make some pretty unsettling sounds (as well as making the vehicle jump) when they go bad.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Nov 2018
Start at the front and work your way back, motor mounts, trans/bellhousing mounts, driveline carrier bearing and u-joints. I'll bet you'll find one of those is the mystery noise.
Get a buddy to help... out of harms way of course, set the emergency brake and put a strain on the drive train feathering the clutch, if its any of those you should be able to see it move. Last edited by Sheepdip; 12-11-2019 at 10:58 PM. |
![]() Join Date: Feb 2002
Bad differentials go ''clunk'' on acceleration, before they go ''BANG'' and quit.
#7 | |
Asking for a friend. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
G80 = Gov Lock
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Since this truck is new to you, I would start with going front to back over the truck, so you know what you got. Brakes, wheel bearings, ball joints, tie rod ends, pitman arm, idler arm, control arm shafts, motor mounts, trans mount, u-joints, carrier bearing, diff, track arm bushings, trailing arm bushings. Grease up what you can while you look around.
With driveline noises, I've jacked up my truck and put it in drive. I parked my suburban in front of it with the bumpers touching, just in case. Helped me find a bad carrier bearing. Figuring out how to recreate the issue will help figure out how to resolve it.
![]() Join Date: Nov 2013
If it has a limited slip....drive it in a tight circle...if it's the posi unit...you'll know really quick...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Ahhh these suggestions are setting up a good project plan, thank you! What a helpful forum.
A mechanic buddy is letting me use his shop, so I come over in the evenings and flounder around, and if I get stuck he bails me out. Pulling in last night he yanked back and forth on the bed and said that it might be loose and shifting on the frame. I don't think that's the source, but it did look a bit loose compared to the cab. He did that also while I was under the truck with a flashlight, I couldn't see anything wrong, but maybe not looking at the right supports. I'll be solo for the next few weeks while he's on vacation so limited to noob wrenching activities and probably a lot of cleanup and prep. I am good at "paint and shutters".... |
