Is my cab shot???
Just curious. Finally getting around to pulling the cab on this thing so I can continue with the frame. Wondering if I need to be on the lookout for another or this one can be saved
![]() Join Date: Dec 1999
Re: Is my cab shot???
Not shot.
I just got done fixing one worse than that... you should come by and look. However, I did spend all summer fixing it. Mine spent the first few years of it's life in Iowa getting salted and had already had the rockers replaced....poorly and a repaint. If you can cut, weld, and grind you can fix that for less than a new cab. |
![]() Join Date: Apr 2008
^ l agree, it can be fixed
71 C10 72 K20 72 K10 Super Kirk |
How's the drip rail look?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Imprortant question above-
If the roof has rust on outer and inner panels, and based on what other rust you can see (there will be more once you start), then I would say it isn't worth the effort
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
X2 on the roof
![]() Join Date: May 2017
Totally repairable
I am In process right now It does take time and patience Have fun |
If you decide it's not fixable, send it to me: it's 'WAY better than the one on my DD
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
![]() Join Date: Nov 2012
My 67 GMC 3500 is worse than that, and it is fixable just like yours!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
![]() Join Date: Feb 2019
Not yet, I have .22 caliber up to 30-06.. I prefer 45 Long Colt in my Schofield Top Break revolver....
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
for 500 bucks you can get a complete floor pan with braces/supports and inner rockers already attached. Every thing you need they have a replacement panel. What do you have to loose?
My thoughts at least |
![]() Join Date: Aug 2004
I repaired similar lower rust on one side of my cab, I’ll do the other side next. It’s doable.
Look at your roof near the top of the windshield opening (visor area) and above the doors. That’s the harder area to repair. There’s some pics and suggestions on the lower repairs at the tail end of my build thread. The good thing about learning this stuff on the lower areas is that it’s way below eye line. So if it’s not dead nutz perfect, it’s not as obvious. Is that a 50th anniversary truck? It looks like the right colors.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#13 |
Old member
Mine looked way worse and it's now fixed. I did it all my self with a little help from my friends. Just take your time and check your measurements good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#14 |
#15 |
Wow, that's weird! After I posted where are the pictures, the pictures populated
#16 |
![]() Join Date: Dec 2009
Keep that cab Alive
![]() Buy a full floor-pan and a welder and some sheetmetal ![]() .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#17 | |
If you get the full floor you still need, outer rockers, cab corners, toe boards, lower a-pillar and lower b-pillar. (5 Patch Panels per side + floor) If you don't get the full floor you also need outer floors, and front/rear cab supports. (8 patch panels per side) I actually had to make a couple more pieces to patch my floor in addition to the outer floor patches I got. It looks like OP might need to get a patch panel for the firewall also. I can't remember the numbers but I think buying all the patch panels only was about 1/2 the price. When I was done I wish I had just replaced the entire floor because I think it would have been easier than all the patch welding I did to the floor. But, I was glad I saved the money! |
#18 |
I did my passenger side that was similar to that. Having never done metal work like that before it took a lot of learning, practice and time but it's not rocket science. If you plan to pay a shop to do it, it will get VERY expensive. Like others have said, if the drip rail/roof is terrible, that's another story.
#19 | ||
"I ain't nobody, dork."
All of that is fixable, and panels readily available. I too would like to see the drip rail, inside roof and "A" pillars. That's the not so easy stuff.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
| Bookmarks |
