Old 12-13-2019, 12:22 PM   #1
Cj92345
64 gmc 305 spread between 3rd and 4th
finally got the gmc 4x4 driving good, when I first got it the tires where 29 tall and the truck seemed very low geared, now I've put 33's on and the the spread between 3rd and 4th seems drastic, really got to get her wound up to go into 4th....normal?
thanks
Cj92345 is offline   Reply With Quote
Old 12-13-2019, 01:36 PM   #2
cerealwars
Re: 64 gmc 305 spread between 3rd and 4th
That's a pretty hefty tire diameter increase.
Re-gearing the rear end is the correct way to fix it.
These drivelines will put up with sustained loads pretty well though, so it's not like you need to fix it in any sort of hurry.
cerealwars is offline   Reply With Quote
Old 12-13-2019, 06:20 PM   #3
TwoFiftyShifter
My 82 has the 4 speed trans with 31s. 2.73 gears. You need to wind her up to go anywhere, but no overdrive needed. Never driven a 305 V6 but it probably gives up some oomph to a 350SBC in normal driving.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-13-2019, 06:54 PM   #4
Cj92345
yeah, 60-62 is about tops, no tach but it seems buzzing
prior owner said he had it re-geared in the 70's to haul a camper on it, but couldn't remember what gears where in it or what he had installed...lol
Old 12-13-2019, 07:26 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Truck looks good..!!....
1st I'd figure out what axle ratios you have in it...you can use a variety of methods to find out...Google how
And go from there
What trans do you have?
Regearing is a option as pointed out by cerial,,,,but you have to do both axles ,not just the rear, as I'm sure you know...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
