Old 12-14-2019, 06:52 PM   #1
ozkiwi
86 silverado air cond upgrade.
I am moving to a much hotter climate and the stock air cond in my truck has never been that great.
It has a new four seasons compressor.
New dryer.
Shut of tap for the heater.
Re gased.
When engaged it sends a vibration through the truck at idle even with the solenoid idle kicker is engaged. Not sure if this normal as it did that with the old pump as well and I thought the new one would eliminate that?
It also kills my gas mileage by way more than I would expect but maybe that's normal also?
Is there a more efficient modern compressor or complete set up I can install ?
ozkiwi is offline   Reply With Quote
Old 12-14-2019, 08:12 PM   #2
calvin78612
calvin78612's Avatar
Re: 86 silverado air cond upgrade.
Vintage Air.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 12-14-2019, 10:01 PM   #3
SunSoaked
SunSoaked's Avatar
Originally Posted by calvin78612 View Post
vintage air.
x2!!!
SunSoaked is offline   Reply With Quote
Old 12-15-2019, 12:20 AM   #4
Dead Parrot
What refrigerant? How much? Was it vacuum pumped before being filled? If the refrigerant was changed, was the old oil flushed out?
R-134 is a lot less tolerant of air in the system and being either over or under charged.
My 75 has the older style long compressor and I don't notice much vibration and I don't have the idle solenoid. Mine costs me 1~2mpg at speed.
Dead Parrot is offline   Reply With Quote
Old 12-16-2019, 11:34 AM   #5
Axle
Axle's Avatar
Axle is offline   Reply With Quote
Old 12-16-2019, 03:54 PM   #6
allengator
allengator's Avatar
I live in Texas.. After talking to a lot of people here, instead of rebuilding the original system, I am going vintage air!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-17-2019, 01:55 AM   #7
Greasey Harley
Greasey Harley's Avatar
I work for a refrigeration company. Our shop truck is a '79 C30 with a 454 and original AC still in place. I went through the system, replaced all the O-rings and both rubber hoses.
Pressure tested it over night, then pulled a vacuum on it with our big Appion vac pump. After it achieved a nice, deep vacuum (500 Microns), I installed the proper amount of R-12 back into the system.
That thing will FREEZE YOU OUT! Even when it's triple digit temps, it's always cool in The Dually. The point being, there is nothing wrong with the design of the factory AC, and parts are still available.
My opinion is worth exactly what you are paying me for it.
-Russ
Greasey Harley is offline   Reply With Quote
Old 12-18-2019, 01:58 AM   #8
Ziegelsteinfaust
-Russ
I do commercial hvac. Blends like r134a can get funky when fractionation has happened sometimes. R12 is pure, and not subject to that issue. In my case it is r410a, and r12 instead.
Alot of mechanics dont vaccum, and noncondensibles stay in. Ruining the performance. My sister's husband was looking at me like I was a freak using nitrogen on a friends truck. The compressor was changed, but I spent time blowing R11 flush through it since it had several dye packets added in its life time.
Ziegelsteinfaust is offline   Reply With Quote
