Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 12-14-2019, 07:44 PM   #1
Madkidd007
Madkidd007's Avatar
70 C20 12v Cummins
$8500
Looking to sell not trade, too many vehicles. Price drop is now reflective of wanting to sell the truck so keep that in mind.
I've had the truck for 16 years now and has a clean title. Factory C10 frame swapped to a correct 3/4 chassis. 92 12valve VE pump rebuilt & tuned, he351 turbo, a518 46rh overdrive trans, makes 41-42 pounds of boost . Rear suspension is trailing arms with airbags which do not leak and front is from disc brakes are from a single wheel square body C30, with the weight of the Cummins it rides just like when it was 1/2 ton with a small block. 3" in and out intercooler with matching pipes. Truck has been overbuilt as I didn't want to have to fix anything. All parts are able to be store bought also, everything was centered around parts for a 1990 R20/R30 series truck to keep things simple and parts available without special order. I'll just list everything in addition to the above to keep questions to a minimal.
Ho52 Eaton rear axle with 4.10 locker
Not sure what all was done to the trans in its previous life but it has an aftermarket purple converter and has never slipped or had a sloppy gear change once. It definitely has some work done to it. Engine was all stock in a work truck with 135k miles when I got it.
Driveshaft is a 1 piece built by Nash truck parts with 1410 joint in the front and the stock 1350 at the axle
32.5” tires on 18x9 wheels
Aluminum radiator with 2 1.25" wide cores(stays under 175 in 90 degree weather) have a new thermostat just haven’t installed as it seems to run too cool
3.5" downpipe to 4" exhaust with a 5” tip behind the passenger tire
Currently have 98% of the parts to convert it to P-pump also
Injection pump has a new head/rotor assembly, new cam plate, 3200 governor spring.
15x.012 VCO nozzle on Bosch injectors from DAP
“The hungry diesel” high volume/low pressure piston pump
Timing advanced to 19-20 degrees(advanced one tooth at pump gear and pump pulled away from the head)
EGTs will not go over 1400 no matter how long you stay in it
All last year didn’t have the grid heater hooked or used the block heater all the way down into the 20s and still fired off great. Verified last night the block heater does work.
Group 31 battery mounted in proper plastic box inside of an old tool box in the bed.
Rebuilt original Bosch starter
Full auto meter gauges(tach, trans temp, boost, pyro, water, oil pressure) trans temp I haven’t hooked up yet
All led dash lights, led interior and floor lights
Newish filters and fluids (trans, oil, fuel) only live a few miles from work
Hyrdroboost conversion using new factory replacement gm parts for a 90 model square body and factory hoses
Curt receiver hitch
Braided Teflon lined fuel supply lines
LED headlights, and not the cheap ones without a cutoff line
LED front running/turn signals and rear tail/brake lights
Factory Chrysler 140 amp alternator with internal regulator conversion
Carpet in good shape
Lokar cable shift conversion using stock automatic column(overdrive is a toggle as I never installed pressure switches to make it automatic)
New complete ac/heater wiring harness and box resealed years back, cables are under the dash but not hooked up as I didn’t have the retainer when replacing the heater core a couple months ago(aftermarket aluminum and think it’s leaking again slightly)
Factory AC truck and compressor on engine, needs hoses made and a condenser to have working air
Heat and defrost does work
Wipers and even the windshield washer squirters work
Sony CD player with USB and Infinity 6x9s behind the seat in cab corners
2" body lift to clear drivetrain while keeping the low hump trans tunnel to keep maximum ground clearance and nothing hangs below the frame
KDP taken care of, new crank and timing cover seal
Needs a couple loose ends tied up(wires cleaned up but everything properly fused, bed wood replaced, 15 gallon fuel cell in the bed as I never bought a tank to go under the truck)
Needs door panels and previously had 6x9 speakers added in the lower doors but they are messed up. Seat has a torn spot that could still be repaired.
Mechanically it is right and no issues going down the highway at 75 MPH and will keep going right past that if you want
Rust issues are pictured and have been this way for the 15 plus years I’ve had the truck as it’s either been garaged or parked under cover. As you can see the inner rocker needs repair but not necessarily a full replacement. Outter rockers need replacing. The truck has its problems but nothing serious as I drive it over half of the week.
I know it’s a lot to read but I try to be very thorough on the good and the little bit of bad. I’ve towed 8k lbs a few times and it handles it great.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 12-14-2019, 07:46 PM   #2
Madkidd007
Madkidd007's Avatar
Re: 70 C20 12v Cummins
And the goods
Old 12-15-2019, 12:08 PM   #3
kidatheart
kidatheart's Avatar
Looks like a ton of fun! If only my lottery tickets would start paying off...
kidatheart is offline   Reply With Quote
Old 12-17-2019, 09:00 AM   #4
doo142
doo142's Avatar
Price??
72 Cheyenne k/20, Custom Camper
72 Cheyenne k/20
71 blazer K/5 2WD 454, 6 sp.
67 Chevy Napco c30 Dump
56 GMC Napco 4x4 short step
66 Chevy K10
68 Chevy C/30 4x4
doo142 is offline   Reply With Quote
Old 12-17-2019, 10:06 AM   #5
Madkidd007
Madkidd007's Avatar
Originally Posted by doo142 View Post
Price??
Sorry asking $11
Old 12-18-2019, 12:42 PM   #6
Madkidd007
Madkidd007's Avatar
I do have a bunch of new parts, dash pad, arm rests, seals, various items. For the right price I’ll let extras go with it
Old 01-14-2020, 10:51 PM   #7
Madkidd007
Madkidd007's Avatar
If anyone is interested, still open to letting it go if it sells before the crew cab. But only selling 1 of the 2. Willing to talk numbers for the right person
Old 03-15-2020, 11:31 PM   #8
Madkidd007
Madkidd007's Avatar
Available again, $8500 this time. Still drive it once a week, price is right as to help someone that will appreciate it.
Old 03-16-2020, 08:57 AM   #9
Aw maaaan…. Wish a could. I NEED that! Good luck with the sale to the lucky buyer
Old 03-16-2020, 12:38 PM   #10
Madkidd007
Madkidd007's Avatar
I know tight. Figured I’d make an easy sell price and have one less vehicle to worry about.
Old 10-20-2020, 08:33 PM   #11
ballencd
Is this still for sale?
1983 M35 (bobbed and converted to dump)
1984 M1010
1988 Chevy Suburban (5.7TBI/TH700R4/NP208)
1991 Chevy Suburban (5.7TBI/TH700R4/NP241C)
ballencd is offline   Reply With Quote
Old 10-20-2020, 10:59 PM   #12
Madkidd007
Madkidd007's Avatar
That’s actually a good question. I haven’t thought much about selling it. So technically yes it’s for sale but no desire to push a sale.
Also all the extras wouldn’t be sold with it, they’d have to stay for the crew cab
Old 02-27-2021, 08:54 PM   #13
Fizoust
I'm legit interested man
Fizoust is offline   Reply With Quote
Old 02-27-2021, 09:03 PM   #14
Madkidd007
Madkidd007's Avatar
Just replied with a PM. I’ve had random spam emails before which is why I said that. Wish I could post videos direct without uploading them to YouTube. Actually just got back from the grandparents in the truck
Old 02-27-2021, 09:13 PM   #15
Fizoust
I get spam too from craigslist ads. I found your Youtube channel with the burnout at the part store. Truck sounds healthy!
Old 02-27-2021, 09:20 PM   #16
Madkidd007
Madkidd007's Avatar
Ha. That was before I rebuilt the pump and it was only fueling enough to make 34 lbs back then
Old 02-27-2021, 09:36 PM   #17
Madkidd007
Madkidd007's Avatar
Ha, figured out how to show some interesting moments.
