Old 12-14-2019, 09:45 PM   #1
Magicalzoomer
60-66 Lower Ball Joint Nut Size?
Hey guys I am in the process of putting on new springs for my 1965C 20 and I’m having issues with the lower ball joint nut. I’ve been told that it is a 3/4 inch not however mine appears to be larger does anyone know what size wrench I need because it’s larger than 15/16 as well
Magicalzoomer is offline   Reply With Quote
Old 12-17-2019, 02:45 AM   #2
61ChevyPanel
Active Member
61ChevyPanel's Avatar
Re: 60-66 Lower Ball Joint Nut Size?
My '61 might not be the same. You need to measure the threaded part. The size socket you use doesn't tell you the size of the bolt but usually a 15/16 socket works on a 5/8-18 nut. Do you have a thread gauge or a caliper to get an accurate measurement? The 18 part of a 5/8-18 nut is the threads per inch.
61ChevyPanel is offline   Reply With Quote
Old 12-17-2019, 07:26 AM   #3
PGSigns
PGSigns's Avatar
Just use a tape measure. I think you need a 1" wrench. When you go get a new wrench get a cheap set of calipers to keep in your tool box. Also if you don't have one pick up a 3 pound ball peen hammer. You will need it to break the taper loos on the ball joint. You can get all this at a Harbor freight and save some money with a coupon.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
