Old 12-14-2019, 11:22 PM   #1
Kootenay64
Kootenay64's Avatar
Speed holes!
Winter project #1, install sound deadener and carpet. Removed seat and old rubber mat and this is what I found, all in all not bad I think. Couple of minor speed holes in the floor as you can see. Will patch with sheet metal and rivet down, question is what to use to seal? Looks like PO has used some kind of black substance, anyone know what this might be?
Also found wide open unused hole into engine compartment, will seal that as well.
Have a carpet kit on the way from LMC , does anyone know how much of the floor this will cover, do I need to remove the fuel tank as well?
Thanks in advance for any help.
The doctor said I wouldn’t get so many nose bleeds if I kept my finger outta there,” - Ralph Wiggum
Kootenay64 is offline   Reply With Quote
Old 12-15-2019, 11:14 AM   #2
Indian113
Indian113's Avatar
Re: Speed holes!
Not wanting to throw water on your parade I think I would weld patches in those holes. I feel that doing it the way you said will allow moisture to get into it and cause more problems down the road.
Indian113 is offline   Reply With Quote
Old 12-15-2019, 11:34 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Speed holes!
Speed Holes - Never heard that term.
Old 12-15-2019, 02:21 PM   #4
oem4me
oem4me's Avatar
Re: Speed holes!
Thats the factory installed sound deadener. Asphalt impregnated felt.
Old 12-15-2019, 02:27 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: Speed holes!
Drag racing weight reduction
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-17-2019, 09:35 AM   #6
jbgroby
jbgroby's Avatar
Re: Speed holes!
Kootenay64,
Insted of rivieting and if you don't have access to a welder, you can shape patches and use panel adheasive which would be better than pop rivets.
If you pickup up a Harbor Freight Air Punch/Flange Tool ($39.00) it will allow you to make a flush patch with sheet metal and use 3-M brand of panel adheavsive. Then fill prime and paint as normal.
jbgroby is offline   Reply With Quote
Old 12-17-2019, 07:35 PM   #7
Heater63
Heater63's Avatar
Re: Speed holes!
agree ^^ just bond with adhesive if you can't weld in proper patches. Pop rivets are just complicating it
292 + TKO500
Heater63 is offline   Reply With Quote
Old 12-18-2019, 05:08 PM   #8
Kootenay64
Kootenay64's Avatar
Re: Speed holes!
Exactly what I'm thinking for now with the formed patches. Need to keep things simple for now, plan on full resto in the coming few years and looks like some floor panels will need to be welded in at that time.
Received the carpet kit from yesterday and scoped things out, looks like fule tank removal will be required - no big deal.
Thanks for all the input!
Old 12-18-2019, 07:10 PM   #9
mick53
Re: Speed holes!
That's a lot of work for a couple of pounds. I think you are supposed to dimple them for strength. Might be easier to hit the bathroom before the race,
mick53 is offline   Reply With Quote
Old 12-18-2019, 08:40 PM   #10
65c10restomod
Re: Speed holes!
I call them rust holes.
65c10restomod is offline   Reply With Quote
