Old 12-15-2019, 12:46 PM   #1
68c10owner
68c10owner's Avatar
rear disc question
My 78 C10 I picked up has a rear disc kit and Im wondering if it will effect the backspacing needed for custom wheels. Right now it has stock steelies so its not a issue but Ive heard it can change the backspacing required and plan to order custom wheels soon. Im not sure of the brand of the kit but it does have a CPP master. They actually dont seem to stop too well but I havent had a chance to do anything to it since its stored at a friends house.
Anthony
68c10owner is offline   Reply With Quote
Old 12-20-2019, 01:50 AM   #2
68c10owner
68c10owner's Avatar
Re: rear disc question
Nobody knows huh?
Anthony
Old 12-20-2019, 08:31 AM   #3
It is hard to say not knowing what brake setup was installed. Depending on what rim size you are planning to go with is the biggest factor. I'd say a 17" or larger rim it will be minimal, but a 15" rim clearing the caliper will most likely be an issue.
Old 12-20-2019, 08:37 AM   #4
68c10owner
68c10owner's Avatar
Thanks. That's another issue I was conserned about. I was planning to go with 15" wheels but the wheels I want already rub in the front because of the thicker casting. I'm worried the rears may be a issue too. Might be just the excuse I need to go with bigger wheels
Anthony
Old 12-23-2019, 09:22 PM   #5
twinturboc10
You could make a couple measurements to compare front to rear using a straight edge and tape measure. Does it have OEM style calipers or aftermarket?
twinturboc10 is offline   Reply With Quote
Old 01-02-2020, 08:56 AM   #6
sambrutay
sambrutay's Avatar
The thickness of the rotor vs the thickness of a drum is what you have to take into account.
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
Old 01-02-2020, 09:12 AM   #7
68c10owner
68c10owner's Avatar
The type of caliper shouldn't matter but it is a aftermarket kit.
I realize the thickness of the rotor vs the drum will determine any change but the truck came with the kit installed so I can't measure the stock set up.
It's not important at this point b uh t thanks for the input
Anthony
Old 01-02-2020, 04:25 PM   #8
sambrutay
sambrutay's Avatar
These are the drums off my 74 GMC
looks to be almost an 1/8" thick (the increments are 16 and 32nds)
Bruce
1964 C10 SWB #Junk
