![]() Join Date: Nov 2015
GM HEI #41 weights and #375 Center plate wanted
Looking for GM HEI #41 weights and a #375 center plate, anyone have some?
Thanks in advance Kirk |
Re: GM HEI #41 weights and #375 Center plate wanted
Anybody?
Post Whore
![]() Join Date: Feb 2016
I can dig around and see, but they may have been modified in the past. Any idea as to year, make and model vehicle they came installed in.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I think it is 1976-1986 trucks and suburbans but not sure.
Anyone!
Post Whore
No luck on finding any of the parts you want.
Unfortunately you will need to be more specific if you want to find such an exact set in a distributor. The weights and plates vary with the vehicle's build specifications. So engine configuration (Displacement, cam, carb), transmission, rear end ratio, vehicle weight, tow package, and the vehicle's dealer destination (i.e. California or a high altitude location like Santa Fe NM). So to find this specific set you will need to find the specific distributor part number. Or find a dealership that is has the old parts books and is willing to help try and locate them in GM's system (if they still exist). Or get lucky and find them here or elsewhere on the interweb. It would be easier to find a competent person to recurve a distributor (on a distributor machine) for your specific application. Having messed with many distributors over the years I have to confess to not paying much attention to the numbers unless I came across an unmatched pair of weights installed and need to try and find a match.
Thanks for checking HO455!
I will keep looking. Thanks again Kirk |
Somebody has to have some of these?
Somebody has got to have some of these?
Nobody has any of these? that's hard to believe.
Looking for only the #375 center plate now, I found a set of #41 weights at a out of town junkyard.
