Old 12-16-2019, 01:54 AM   #1
Short 3/4
Short 3/4's Avatar
Aluminum Radiator Mounting
What are you all doing to mount square tank type aluminum radiators using the stock V8 style U shaped saddles with the rubber inserts? I shaved down the rubber inserts, but don't like that the metal part of the saddle is now real close to the tank, and the fit is not so good. I reached out to both Champion Radiator and Brothers and while both understood the problem, neither had a solution.
I know somebody out there has figured this out.
Thanks,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 12-16-2019, 08:58 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Aluminum Radiator Mounting
Here is what one member did - http://67-72chevytrucks.com/vboard/s...d.php?t=615934
Old 12-16-2019, 09:56 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
I also fabricated my top mount (mine was missing from the previous owner, so I had to make one anyway).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-17-2019, 11:27 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I had to add about 3/4” to the top mount and then I used thinner rubber pads for the bottom.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-17-2019, 07:30 PM   #5
Heater63
Heater63's Avatar
I fabbed a bottom U channel by welding up thin angle iron. Modified a stock upper mount by cutting and welding. Applied some rubber sheeting to both for cushioning via adhesive silicone.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 12-17-2019, 07:49 PM   #6
oldtrux
oldtrux's Avatar
i used an aluminum rad from RND FAB.bottom fit in the original saddles but
top was wider.i bought a spare top mount,sliced it up and made a bigger one out of two.used original rubber .looks original.all ideas above work good too.
oldtrux is offline   Reply With Quote
Old 12-20-2019, 06:41 PM   #7
Short 3/4
Short 3/4's Avatar
Some great info and ideas. Of course not as easy as expected, but I'm used to that.
Thanks to all who replied,
Tom
292-SM420-T221
