![]() Join Date: Oct 2007
6 Cylinder Offset Airleaner Assembly
After Christmas Price Drop $150.00 plus shipping
UPPER LID - No dents (has factory dimples) and recently blasted and painted. LOWER LID - No rust other than surface rust on portion of inside. Could use blasting and re-paint. HEAT RISER - Has screws, snorkel to air cleaner and tin bracket that bolts to intake studs. SUPPORT BRACKET TO BLOCK - Has stud with wingnut. CARB STUD - Has wingnut CARB SPACER - With factory vent hose to valve cover Money order or cashiers check. Respond in thread. If you are in PA, MD, VA, DE, NJ or Western OH I can probably assist with delivery to your door step. Last edited by My72BB; 12-27-2019 at 10:30 AM. |
Re: 6 Cylinder Offset Airleaner Assembly
After Christmas special - $150.00 plus shipping.
Junior Member
![]() Join Date: Aug 2016
If this is still available, would you be able to do $125 shipped to 49418?
