Old 12-17-2019, 12:24 PM   #1
CG
BlahBlahBlah
Auto tilt question
My guess is its going to be fine, but … I have an auto tilt column stashed away and Im pretty sure its a column shift. Ill be using an auto floor shift though. Do I have to do anything to the internals or wiring of the column so it doesn't mess with starting, neutral safety .. etc?
The entire truck will have a new harness nose to tail.
And I absolutely don't want to pay the extreme price of purchasing an actual floor shift auto tilt column.
Old 12-17-2019, 01:09 PM   #2
clay68c10
clay68c10's Avatar
Re: Auto tilt question
Just don't use the neutral safety/reverse switch on the column. You'll need to use the reverse light connection on the trans as well.
If you get a new harness for a floor shift it should already be taken care of.
The turn signal switch is separate from NSS & reverse lights.
If you're handy with a welder and epoxy/filler, you can make your own floor shift tilt out of the auto one you already have.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-17-2019, 04:02 PM   #3
CG
BlahBlahBlah
Sounds simple enough. Ill have to pull out my wiring diagram for the column and also check my new harness.
Old 12-17-2019, 06:23 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If you can't find a manual shift collar you can modify yours.
I removed the shift handle boss and indicator by hack sawing and grinding, cutting a couple of pieces of thin sheet metal that fit tight in the openings, and JB welding them in. Be sure to slip a thin piece of cardboard or metal down inside the collar to keep any JB Weld out of the inside of the housing. I wish I had taken more pictures.
LockDoc
Leon
Old 12-18-2019, 06:45 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Auto tilt question
Here the link to my thread on shaving a auto collar to make it a floor shifter in my ramp truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=760936
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-18-2019, 10:39 AM   #6
CG
BlahBlahBlah
Good info guys ... thanks again.
