![]() Join Date: Dec 2003
WTB 3 speed overdrive transmission
Looking for a 1965 or newer 3 speed overdrive transmission.
It needs to have the 7 bolt side cover.
Ike 68 swb fleetside heavily modified TPI engine. Ford AODE automatic (yes Ford!), 12 bolt 4:11 positraction rear axle, 4 wheel disc brakes, wood dash and LED instrumentation, BMW bucket seats, outside stock except for dark red paint. |
![]() ![]() ![]() Join Date: Jan 2018
Re: WTB 3 speed overdrive transmission
Got one here in Georgia. I haven't gotten it cleaned up or taken any pics of it yet, but it has the entire wiring harness, relay, solenoid, governor, and lockout cable. The solenoid engages when power is put to it. I will stick the relay onto the wiring harness in my truck to see if it works. Also will check to see the condition of the governor and cap. Only thing that is missing is the kickdown switch on the carburetor. Engine had already been pulled from the truck.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Thank you for the reply.
I have someone in Kansas that thinks he has one. I would prefer it since it is closer. Going to be a few days to get an answer because of the snow. Can you wait until the end of the week?
Yes, I can wait. I'm working as a driver helper for UPS, so I probably won't be able to check all the things until this weekend anyways
![]() Join Date: Oct 2007
cwcarpenter, if Red68 passes, I am possibly interested in your OD transmission, and I'm not far from you. If he definitely goes in a different direction, and you are still interested in selling, shoot me a PM. I am in no hurry and do not under any circumstances want to jump the line, if he needs it I'd rather he have it.
Hey Mike, Red68 has first dibs. If he doesn't take it, I'll be putting it up for sale on the board. Will probably be after Christmas until I get it ready to go as I'm working 6+ hours a day delivering packages with UPS. Gotta pay for truck parts somehow
#7 | |
Sounds good, thanks! |
Just bought an overdrive trans from SHORTSTEP60.
So CWcarpenter let MikeN have a go at your transmission. These forums really help when someone like me is trying to find hard to find parts
#9 | |
Mike, it looks like I might not be able to do the testing and cleaning until after Christmas. UPS is always super busy this time of year which keeps me busy too!
No sweat and no hurry at all, thanks!
Hey Mike, I got some pics and was able to clean up the trans today.
Solenoid works, relay works (it's currently plugged into my truck and worked great as soon as I plugged it in), the governor has no visible cracks on the cap, the wiring harness is complete, the lockout cable is there and moves back and forth well, but the handle is not in great shape, the shift arms shift well and are not worn out, reverse on the shifter locks out the overdrive. Wiring harness is not cut. It comes with the bell housing, clutch fork, and old throw out bearing. I can also get you the shift arms from the truck it came out of. It came out of a 68 c10. The trans is with me here in Woodstock, GA. I am asking $800 obo.
More pics
#13 |
Ill take it. Sending you a PM to make arrangements to come pick it up. Thanks!
Also, I would like to have the shift arms if you can grab them. |
#14 |
I replied to your PM before I read this post. I'll grab the shift arms for you as well.
#15 |
![]() Join Date: Nov 2013
I have one of those overdrive trans four bolt side cover I pulled out of a 64 don't no much about it fluid was very clean.
#16 |
Trans sold to MikeN. Thanks Mike, and I hope you enjoy it!
#17 |
Thanks again, I’m looking forward to getting it installed. Going to have it freshened while I do my homework on a correct installation. Hoping to have it up and running early summer.
#18 |
Heck yeah man! If you've got any questions, don't hesitate to ask. I love sharing the knowledge that I've gained about these transmissions
