Old 12-19-2019, 02:20 AM   #1
CustomGMC’s
Got the motor turning
The engine in my 67 was stuck from the PO leaving the heads off for some years (it looked rough). After spraying it all down with penetrating oil and cleaning up the cylinders we were able to slowly get the motor turning over and all seems good so far. The cylinders all cleaned up really nice. I was really planning on replacing it but I’m going to give it a chance and maybe we will get lucky if nothing else is wrong. It was supposed to run really strong but they “took the heads off to rebuild and never got them back on”
I know it’s a gamble and we should probably just have pulled it but for a $40 gasket kit and some supplies It’s a cheap experiment.
Hopefully have it running sometime in the next week.
CustomGMC’s is offline   Reply With Quote
Old 12-19-2019, 08:07 AM   #2
rpmerf
rpmerf's Avatar
Re: Got the motor turning
I dig it. What have you got to loose, right? I think my biggest fears would be either crap in the oil pan getting stuck in a port, or loosing compression depending how bad the cylinder walls were. Might try and flush that oil as much as possible before you run it, then give it an oil change quickly afterwards.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-19-2019, 08:39 AM   #3
yuccales
yuccales's Avatar
I bet she runs!
yuccales is offline   Reply With Quote
Old 12-19-2019, 10:00 AM   #4
maverickmk
maverickmk's Avatar
You'll be fine. Have any before pictures?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 12-19-2019, 10:32 AM   #5
CustomGMC’s
That’s what I was thinking. I pulled the drain plug and there was only about a quart of oil that was in it so hopefully they drained most of it when they took it apart. I sprayed penetrating oil all through the lifter valley and down onto the cam and dumped a quart of oil in it so hopefully that washed out some of the dirt and stuff and then drained it. I’m going to run it and then drain it all again with it warm so hopefully any remaining sludge will wash itself out. Someone had bored it 60 over at one point and the freeze plugs in the block have been replaced so not sure on how many miles on it.
Old 12-19-2019, 10:33 AM   #6
CustomGMC’s
Originally Posted by yuccales View Post
I bet she runs!
Crossing fingers!!
Old 12-19-2019, 10:35 AM   #7
CustomGMC’s
Thanks, I don’t think I took any. The cylinders had some surface rust and it was very dirty from years without a cover on it
Old 12-19-2019, 10:53 AM   #8
truckster
truckster's Avatar
What did the oil look like when you drained it? If there was any water in it, I'd be concerned that water might have made its way past the rings and to the crankshaft.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 12-19-2019, 12:53 PM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Pour a quart of Marvels Mystery Oil in with 4 quarts of your favorite zinc ladened 30w oil and fire that old girl up. Run her through a couple of heat cycles tuning her up and change the oil and filter. Take a compression test to reveal any possibly weak cylinders and you should be good to go...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-19-2019, 12:55 PM   #10
maverickmk
maverickmk's Avatar
Good call on the zinc.
Old 12-19-2019, 02:50 PM   #11
Keith Seymore
Keith Seymore's Avatar
Got the motor turnin'.....
Head out on the HIGHWAY....
Looking for adventure....
In whatever comes my way....
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-19-2019, 02:51 PM   #12
Keith Seymore
(sorry)
1979-1986
1986 - 2019
Old 12-19-2019, 02:52 PM   #13
maverickmk
maverickmk's Avatar
Old 12-19-2019, 03:46 PM   #14
Mts67C10K20
Mts67C10K20's Avatar
NICE
it's a sbc it will run when all others fail
Clean
Flush
Clean
Flush
And as always hold your breath when you hit the key
Mts67C10K20 is offline   Reply With Quote
Old 12-19-2019, 09:33 PM   #15
CustomGMC’s
There was about a quart of some really dark and thick oil. I think that part will be okay
Old 12-19-2019, 09:37 PM   #16
CustomGMC’s
Good idea on the mystery oil! I need to get some more of it.
Old 12-19-2019, 09:39 PM   #17
CustomGMC’s
Lol that’s funny! Hopefully heading out on the highway, I need a fun driver!
Old 12-19-2019, 09:40 PM   #18
CustomGMC’s
Originally Posted by Mts67C10K20 View Post
NICE
Clean
Flush
Clean
Flush
👍 that’s what I’m hoping
Old 12-19-2019, 09:55 PM   #19
kidatheart
kidatheart's Avatar
Which oils are high in zinc?
kidatheart is offline   Reply With Quote
Old 12-19-2019, 10:11 PM   #20
Boog
laying low
Boog's Avatar
Externally the engine shows it's age but my goodness, inside it cleaned up real nice. The piston tops and cylinder walls look great. Hardly any ring groove to be seen. Having it opened up this far aren't you curious what shape the cam is in too?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-19-2019, 10:20 PM   #21
maverickmk
maverickmk's Avatar
I'm not aware of any oils currently available with an amount of zinc to protect flat tappet cams these days. There are small bottles of zinc additive available at all the usual auto parts stores.
Old 12-19-2019, 10:55 PM   #22
kidatheart
kidatheart's Avatar
Ok. Thanks.
Old 12-19-2019, 11:03 PM   #23
CustomGMC’s
You are right about that, it cleaned up a lot more than I was expecting. I am curious about the cam but I’m really just wanting to see if it will run and it’s not knocking or any bottom end problems before I put any real money in it.
Old 12-19-2019, 11:05 PM   #24
CustomGMC’s
I was looking at some different zinc additives, STP sells one and some others. Any suggestions on which one I should get?
Old 12-20-2019, 12:36 AM   #25
toolboxchev
Did not look and see if you lubed a (new) cam and lifters???
Valvoline VR1
Comp Cams engine break in additive.
Best stuff I found out there and 89 thousand on a top end rebuild proves it to me.
toolboxchev is offline   Reply With Quote
