Old 12-20-2019, 11:39 AM   #1
msg
Is it ok to use DOT 5.1 brake fluid in a new set up on a 66 C10?
Im redoing the components in my braking system and will have a fresh start. New Master Cylinder, Calipers on the front, cylinders on the rear drums and new lines. I was about to buy DOT 3 and fill er up but Im reading that DOT 5.1 is compatible with DOT 3 and is better. Anyone done this already? Or should I just stick with DOT 3?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 12-20-2019, 02:01 PM   #2
wixthedog
wixthedog's Avatar
Re: Is it ok to use DOT 5.1 brake fluid in a new set up on a 66 C10?
5.1 is compatible with 3 and 4, but not 5.
5.1 and 4 both have higher boiling points so if that is something you are after it would be wise to use it. If not, and you don't want to pay the premium, Dot 3 will still work fine.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
