Old 12-22-2019, 03:56 AM   #1
chev-obsession
chev-obsession's Avatar
Question Will 73-87 shoulder belts work in our cabs?
I was searching the wrecking yard today for some parts I’ve been needing, came across a square body truck (not sure on exact year). It had a nice set of shoulder belts, I thought it would be a cool little retro fit into my ‘65.
Has anyone used the square body shoulder belts in the 60-66 trucks?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 12-22-2019, 06:30 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Will 73-87 shoulder belts work in our cabs?
FAQ Section just above - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
There are posts on seat belts such as:
Seat Belts
Aftermarket Seatbelts???
a long thread about seat belt options
Seat belts for stock bench seat, purchase and install info
a thread with information about a aftermarket seat belt kit for a bench seat, with photos.
1965 Seat Belts??? : July 2010 /60+ posts
anybody make the seat shoulder bolts : November 2013
1966 shoulder strap cab holes : April 2011
Seat belts???? : August 2014 /+15 posts, some photos and scanned diagrams
(what is) the best 2 point retractable seat belt? : September 2014
66' 3 Point Seatbelts_B Pillar Plug... March 2014
Old 12-22-2019, 12:52 PM   #3
chev-obsession
Thanks for the reply, all the threads look like aftermarket seat belts. I did a search before posting this and didn’t see anything about the square body shoulder belts. Just curious if anyone has tried it or will they just not work?
1965 c/10 swb
1969 c/10 lwb
Old 12-22-2019, 01:26 PM   #4
crewguy
I'm putting belts from a 78 in mine. I converted to big window and reinforced the rear panel where the shoulder strap would attach before installing in the truck...welded on a nut from the backside to accept the should anchor. Measured from the 78 top of seat bottom(bum portion) to the shoulder strap mount and used the same distance on the 65.
crewguy is offline   Reply With Quote
Old 12-22-2019, 08:30 PM   #5
chev-obsession
That’s a good idea! I wish that I would have thought of that before I welded in my BBW panel. You should post some pics when you get it finished
1965 c/10 swb
1969 c/10 lwb
