Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-22-2019, 07:38 AM   #1
JA50N
JA50N's 86 GMC: A rust wars story
I'm going to start a build thread since I got some pretty key components for my build yesterday, but first let's go back....
I picked this truck up in early May from a buddy on the Eastern Shore.
Untitled by JASON MCKIMMEY, on Flickr
It's a 1986 GMC Sierra Classic 4x4 SB. It has a few rust issues as most do in this part of the mid-atlantic but I can deal with that. It also has had a 350 dropped in to replace the tire 305 which has less than 20K on it. Bonus.
The day I brought it home:
I started doing some stuff to the interior to make it more livable.
LED dash lights
Now that the interior was livable and I could set my cell phone on the dash without losing it inside it, lol, I moved to piddling around with he exterior.
I added some 2" bolt on wheel spacers to make this happen:
So after that, I just drove it around when I wanted to and didn't do much to it. I pondered where I wanted to go with it and finally after some lucrative OT at work this happened:
4.56 open diff 3/4 ton 14 bolt and dana 60 front to match. So now 35's are on the way and I am trying to decide on 3 or 4 inch lift to go with it. I don't want it to be super high. This thing will be used off road so it needs to not rub even when flexed and tires stuffed.
So I think my path is clear now, lol.
Stay tuned as I refurbish these axles, get my tires and wheels in, and pick out the lift. Any pointers for those that have been down this path is greatly appreciated!
JA50N is offline   Reply With Quote
Old 12-22-2019, 01:24 PM   #2
dmack91
dmack91's Avatar
Re: JA50N's 86 GMC: A rust wars story
Nice truck and upgrades. You will need at least 4" of lift for 35's. I have a 4" with lt315\75r16 tires, which are around 34.5" , and while I have no rubbing issues, if it was flexing off road much, I'm sure there would be sheet metal carnage. The lower back corner of the front fender openings would be the first to go unless you do some fender trimming. You can see in the pic how much room there is. Wheel offset will also affect the clearance. Mine have no offset and I don't rub at all, but if you offset them out,you will probably rub.
Keep us posted.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 12-22-2019, 02:34 PM   #3
You have made good progress on it. Looks good.
Old 12-22-2019, 02:51 PM   #4
Matt Man
Matt Man's Avatar
My 81 k10 has a 4" lift with 35's and with my 8" wide wheels I can flex a decent amount before it rubs.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-22-2019, 06:44 PM   #5
JA50N
Well I plan on running a 8" wide wheel with a 4" back spacing and pushing the front axle forward 1" so hopefully that will allow clearance when stuffed of the 315/75 R16's. I will also be properly setting up the bump stops once the lift is on and I check clearances. If not, I'm not afraid of a sawz all. This truck isn't going to look nice ever. It's going to be purpose built and if a little bit of sheet metal gets in the way, that's not going to stop it. lol.
Old 12-23-2019, 09:59 AM   #6
jhama78
jhama78's Avatar
Subscribed to see my old truck become awesome.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 12-26-2019, 06:33 PM   #7
JA50N
Update on the progress up to today. Have been painting the front axle and doing some research on where to get a Bilstein steering stabilizer. Seems like a pain int he butt to find. The compressed length of the leaky stock one is 14.75" and the extended length is 23.00" according to my rough measurements. Bilstein's website lists a model for a later model F-350 that is 14.96 compressed and 23.03" extended. I'm not sure it that will work and the bushings can take up that .25" difference. Offroad Designs has a Bilstein stabilizer listed on their website so I am going to give them a call tomorrow to see which one it is.
I also started disassembly of the 14 bolt. I got the Ubolts cut and off the axle and was able to disconnect the mangled hard lines. The axle is out of a 78 so I am assuming it has SAE fittings and since my truck is an '86 it should have metric correct? Any help here would be appreciated.
I have my tires now but I think I am going to wait on the wheels for a bit.
Any way, here's a few pics. As usual constructive feedback is welcome.
Crappy leaking pinion seal is out and new one is in on the 60.
Brake calipers and pads should go on tomorrow as well as painting the short side axle tube and C-hub. Still waiting on the new diff cover to come in and once that is installed then I can paint the center chunk.
Old 12-30-2019, 08:52 PM   #8
Jake Wade
Jake Wade's Avatar
Man, gonna be a nice build. Ultra strong front and rear you got there.
Jake Wade is offline   Reply With Quote
Old 12-31-2019, 12:08 PM   #9
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Killer truck!
--Josh
Old 01-02-2020, 07:01 PM   #10
JA50N
Since everybody loves pics, some updates. Some parts rolled in today. Should have the tires and wheels mounted and balanced this weekend.
Old 01-05-2020, 03:57 PM   #11
JA50N
So good news and bad news. Good news first. The front axle is ready to go under the truck.
Bad news, got the hubs and drums off the 14 bolt and looks like the brakes are junk. All the parts aren't even there.
Does anybody have a lead on a source for 1984+ backing plates for a 14 bolt that are the 11" brakes? I can't seem to find them anywhere. I can find the 13" brake backing plates but I'm not sure if I want to switch to those.
Old 06-03-2020, 07:47 PM   #12
JA50N
Massive update. See pics below. the front should be going under the truck this weekend.
Decided to go disc on the 14 bolt. Here it is ready to weld shock tabs on and then go under the truck.
Wheels and tires mounted up.
Custom made Alcon front springs with the pin moved 1" forward.
Other suspension goodies, new shackles front and rear, all new mounting hard ware, etc.
Shocks are on the way and hopefully will have them by the weekend. Stay tuned for more.
Old 06-04-2020, 08:24 AM   #13
Katrina/10
Katrina/10's Avatar
I bought a set of those Milestar Patagonias from Amazon, I like them.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-06-2020, 05:50 PM   #14
JA50N
Getting closer. No going back now.
Old 06-07-2020, 04:25 AM   #15
wixthedog
wixthedog's Avatar
It sure is coming along, great progress and updates!
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 06-07-2020, 09:06 AM   #16
blazer2007
what brand of wheel spacers did you use
blazer2007 is offline   Reply With Quote
Old 06-07-2020, 10:26 AM   #17
JA50N
Bulletproof Off Road Adaptors (Bora).
Old 06-13-2020, 07:10 AM   #18
JA50N
Incremental update:
Axle and shocks are in. Brake lines, driveshaft U bolts and crossover steering are in route. Going to Napa today to order a 2wd steering box.
Old 06-13-2020, 04:33 PM   #19
JA50N
2wd steering box installed. Awaiting arrival of ORD crossover steering kit.
Old 06-17-2020, 09:07 PM   #20
JA50N
Small update. Brake lines are in and hooked up and I took a couple motivational pics.
Old 06-17-2020, 10:28 PM   #21
JJH Jimmy
JJH Jimmy's Avatar
Sweet truck! I love your build. Be careful with those harbor freight jack stands. There Is a recent recall on some of them for failing!
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-18-2020, 06:31 PM   #22
JA50N
Thanks. Only the big ones are harbor freight and they aren't the ones on the recall. The other little ones are craftsman.
Hopefully I will get the rest of the steering tomorrow for a weekend install.
Old 06-19-2020, 12:08 PM   #23
Jeepwm69
LED dash lights
Have specifics on the dash pad (or is it a cover?), LED's, and gauge overlay that you used? That looks great!
Jeepwm69 is offline   Reply With Quote
Old 06-19-2020, 04:39 PM   #24
JA50N
Dash pad came from this guy:
http://67-72chevytrucks.com/vboard/s...d.php?t=736613
The bezel is from LMC truck as are all the other trim pieces.
The LED lights I just searched for on Amazon.
Old 06-20-2020, 03:30 PM   #25
JA50N
Saturday update. Having to dodge rain but I have made some good progress.
Rear axle out.
These things, yeah F*** them, lol. Pain in the ass.
One side shackle flip done before the hard rain came and shut me down.
