Old 12-22-2019, 02:43 PM   #1
OldCreek
OldCreek's Avatar
Aftermarket electrical parts
Tell me about your thoughts/experience on aftermarket electrical parts.
I've been throwing a code for over 10 years and have replaced almost every part associated with it. I started with changing the accelerator pedal position sensor for a p1125 and p2125. It worked initially but within days the problem resurfaced so I thought it was due to another issue. (When you rework your own harness and buy an engine off craigslist there's always doubt/questions.)
10 years later and a lot of intermittent down time not using the truck, I think I'm back to this part. It is a Dorman part. Now I'm buying a different company's part to replace this...fingers crossed.
With a lot of internet research I've heard some rumblings about using aftermarket parts. What say you?
Lately I try to buy AC/Delco parts for my other truck/cars. Sometimes that's not an option. Any specific companies you like/dislike?
Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 12-22-2019, 02:57 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Aftermarket electrical parts
I try to stay acdelco whenever possible...other than that i look for made in USA
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-23-2019, 12:46 AM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
How much are you saving.. aftermarket vs dealer...
And second what are you working with?
Swap wise? harness?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-24-2019, 06:28 PM   #4
OldCreek
OldCreek's Avatar
Swap wise? harness?
2005 6.0L Lq9 with 4l60e
* Reworked the stock harness and used all the stock components, including maf, map, ecm, tac module/wiring, pedal position sensor, throttle body and sensor, o2 sensors
*Swapped out one at a time in this order: Dorman pedal position sensor, New tac module and it's wiring harness, APDTY throttle body sensor, Current Performance wiring harness with new Bosch O2 sensors, new Hitachi throttle body with sensor, and just now a new Standard Motor Products pedal sensor
We'll see if I get the same error code with the new pedal position sensor. Maybe a new sensor from the dealer if it happens again.
Otherwise, what's left? A NEW ECM, map sensors, maf sensor.
Anyways, more of a question as to success/failure with aftermarket electrical parts....
I buy parts online for convenience. I'm happy to pay extra for quality. I just don't have the experience to know which company has quality parts...
Old 12-27-2019, 04:55 PM   #5
truckdude239
truckdude239's Avatar
i have used alot of dorman parts over the years i've had good luck and bad luck i try to stick with ac delo /oem brand when ever possible
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-28-2019, 05:32 AM   #6
Wgesnerjr
Wgesnerjr's Avatar
I had problems using Bosch O2 sensors. Replaced both with AC Delco and had no issues since.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 12-28-2019, 10:19 AM   #7
jjzepplin
jjzepplin's Avatar
subbed
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-28-2019, 05:13 PM   #8
truckdude239
bosch o2 sensors are the worst i run a repair shop and will not use them it either oem brand or denso
David fuller
2000 Tahoe 5.3l 378
