Old 12-23-2019, 02:40 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question Hooker Blackheart Engine Swap Motor Mount Kits 12621HKR ??
Anyone use them? Stock bellhousing position?
Eliminating the clam shell mounts would open a bunch of clearence. I want the NV4500 to sit in the exact same position for driveshaft, transmission crossmember, and shifter hole reasons. I am going with a boosted setup and building a turbo log manifold from scratch, but it would make my life a lot easier if I could reuse the factory 10S20F Denson style compressor and mount. It would eliminate any reason to move the battery too.
Thanks.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
