Old 12-23-2019, 12:38 PM   #1
Pure-Juice
Proper backspacing for 20”x12” rear rims
Hello. I have a 1969 C10 with the narrower rear end and looking to see what backspacing I would need to order a set of 12” wide wheels. The truck will be a fleet side. Currently there is no bed on it so I am unable to take measurements. I will be mini-tubbing the new bed to accommodate the wider rims and tires.
I have done a ton of research on here before posting but I’ve seen answers all over place. From what I can tell, the consensus is 7.5”. I’ve read that is heavy on the conservative side. I wanted to see if anyone is running a 7” or even a 6.75” with success.
Thanks in advance for everyone’s help.
Pure-Juice is offline   Reply With Quote
Old 12-24-2019, 02:37 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Proper backspacing for 20”x12” rear rims
I don't know if you saw this thread from a week or so ago.
http://67-72chevytrucks.com/vboard/s...d.php?t=798043
LockDoc
Leon
Old 12-24-2019, 04:34 PM   #3
Pure-Juice
Thanks. I did see that post but I was really hoping to hear from someone who actually has a 12” rear wheel installed rather than relying on educated guesses. Hopefully someone with a similar setup will reply.
Old 12-25-2019, 12:44 PM   #4
un4gvn!
un4gvn!'s Avatar
Mine are 15x12 with a 7" back spacing. The only modifications I did was to the wheel tubs and I cut the bed floor all the way into the frame rails. I also have wheels that are 15x14 with a 8" back spacing. I didn't put tires on them yet. One thing I didn't like about this set up is the wheel tire combo has a lot of weight. The reason I did this is I race this truck and I needed traction.
un4gvn! is offline   Reply With Quote
Old 12-25-2019, 09:17 PM   #5
LockDoc
LockDoc's Avatar
How much room do you have between the inside of the tire and the frame with the 15x12 with a 7" backspace? Also, could you lower the rear of the truck without the outside of the tire hitting the outside of the bed? I'm trying to figure out if I need a 7 or 7.5 BS for mine.
Thanks,
LockDoc
Leon
Old 12-26-2019, 12:09 PM   #6
un4gvn!
un4gvn!'s Avatar
I have just under 3" from hitting the frame and inch and a half from the bed side. I also added on to the splash guard.
Old 12-26-2019, 10:11 PM   #7
LockDoc
LockDoc's Avatar
Good deal. Thanks for that.
LockDoc
Leon
Old 12-26-2019, 10:48 PM   #8
Pure-Juice
Un4gven!,
Thank you sir. Exactly the information I was looking for. Congrats on a sweet truck.
