Old 12-23-2019, 09:18 PM   #1
bigmoe
bigmoe's Avatar
Carpet install - Glue?
I bought a carpet from Auto Custom Carpets. Thick pile with the attached jute backing and the floor has new sound deadener. I watched a carpet install video on you tube and they used spray can glue. I helped a buddy with an install a few years ago and we didn't use any glue and I think it turned out okay. What have others done?
bigmoe is offline   Reply With Quote
Old 12-23-2019, 09:24 PM   #2
65 GMC
Re: Carpet install - Glue?
Just put some in my 65 C10 the first part of November. I didn't use any glue. I figured that with mine having the SM420 transmission I may have to take the carpet back out someday, if I ever need to remove the transmission.
65 GMC is offline   Reply With Quote
Old 12-23-2019, 09:38 PM   #3
bigmoe
bigmoe's Avatar
Ya I wonder what kind of mess it would make to pull off.
Old 12-23-2019, 09:58 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I didn't use any adhesive in my install.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-24-2019, 04:21 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I did not use glue when I put carpet in my panel. With the bucket seats, sill rails and floor shifter boot, it was not coming up or moving.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-26-2019, 08:13 AM   #6
PGSigns
PGSigns's Avatar
I used the same carpet and just laid it in and it has been fine. I did set it in the sun on a warm day for a few hours to get it back to where it looked good after taking it out of the box. Been in there about 5 years now with out an issue.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-26-2019, 05:41 PM   #7
bigmoe
bigmoe's Avatar
Went in fine without glue. I'm impressed with the quality.
Old 12-30-2019, 01:08 PM   #8
Heater63
Heater63's Avatar
^^^ what they said, no glue.
292 + TKO500
Heater63 is offline   Reply With Quote
