![]() Join Date: Jan 2012
using a one piece driveshaft in a swb question
Anyone here using a one piece driveshaft in a shortbox? what did you use? im looking for one I wont have to get cut down/
my set up is a 454 with a th400 (don't have the trans yet) lowered 4inch in the front and 5 in the back and I also have a CPP trailing arm crossmember installed with the larger driveshaft loop. I have a one piece driveshaft I took out of a 69 swb that had a manual 3 speed on the column but not sure if it would be long enough, any help would be appreciated |
![]() Join Date: Jul 2008
Re: using a one piece driveshaft in a swb question
My ‘65 swb had a 6 cylinder with 3 speed and a 1 piece drive shaft. When I put in the 327 and 700R4 I had to have the drive shaft shortened (327 mounted in the rear engine mount holes in the frame) also I’m lowered 2.5 front and 5 rear and stock crossmembers.
1965 c/10 swb 1969 c/10 lwb
There are to many things to consider just to give you a number , You really have to have engine and trans in place and truck must sit on all 4 wheels on the ground to get the proper number , and then who ever you are dealing with must understand how you got your number ,not everyone measures from the same points . I have to ask , but why are you not in the market for a new driveshaft , you spent a lot of time and money to get to this point ,so why use a 40 to 50 year old driveshaft, new built are not alot of money
Old member
I just did this on the 68 long bed conversion to a short bed. I bought a short bed frame so I wanted a 1 piece cut down. Late model drive shaft. New U-joint cut to my measurement and it was $100.00. With the truck sitting how you will drive it. Wheels on the ground and suspension at the riding settings, take the drive shaft and push it all the way into the transmission then pull it out 1".
Measure from center of front U-joint to rear u-joint and this is how long you want the shaft. This is per the drive shaft company I used. Carolina drive shafts. Disregaurd the picture that it's not setting straight. I had to move the cross member it wasn't straight. It's straight now. ![]() http://www.carolinadriveline.com/PDF/measurement2.pdf
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I was hoping id be able to do this without taking it to a shop because the nearest place is 3 hours away and im also hearing impaired so making calls is very difficult for me
At the body shop.
Get your measurements and do it online?
" That didnt make it any newer " " Dont antique the equipment " |
#7 | |
Old member
You need to put eng and trans in and take the measurement, I was able to use my original 3 on the tree 6 cyl. driveshaft when I converted to 327/ 4L60 combo.You have an option to move motor forword or rearword using motor mount holes on frame.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
![]() Join Date: Jun 2005
I used the original driveshaft out of my ‘70 that originally had a 250/3OTT and had it shortened and balanced with new u-joints and a new weld yoke. My 402 is in the front 2 holes. IIRC the measurement was 54.5 center to center from front to rear joint with driveshaft extended 1” from the rear of the TH400 trans. My truck is stock height with 15” wheels. As stated make sure truck is on the ground at normal ride height when you take your measurement. I have had the truck up to 100 (speedo buried) with no vibration.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
| Bookmarks |
