Old 12-24-2019, 02:28 PM   #1
kens65fb
Will these wheels fit ??
I was thinking of these wheels and tires for my 64 C10
4 inch drop both front & rear
5 lug conversion already done.
Brand:
U.S. Mags Standard U108 Polished Wheels
kens65fb is offline   Reply With Quote
Old 12-24-2019, 09:26 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Will these wheels fit ??
You should be able to get up to a 10" wide wheel under a fleet side.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-25-2019, 08:30 PM   #3
kens65fb
I don't want to run 10" rims in the rear, if I go with all 8" wheels, I can cross rotate the tires.
Would the these wheels fit my fleet?
Old 12-26-2019, 12:17 AM   #4
Chevy Fleetside
I said you can fit up to a 10" tire. 8's will fit. I believe you will need about a 4" back space. I have 8" rims on my truck running a 4" Backspace. They fit with no problems.
Old 12-26-2019, 07:43 AM   #5
PGSigns
PGSigns's Avatar
Before I say yes or no you need to tells us a size for the wheel you plan to use and the tire you want to run. I have run 8" wheels all the way around on my 66 and in the front with the disc brakes some tires will hit the fender. In the back the 255's I have under it now have a wider section width than the last set and they rub on the inner wheel house.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-26-2019, 01:13 PM   #6
Chevy Fleetside
Jimmy
The rear tires on my truck are 275/60/15 and I have 255's up front. I don't have a problem with any rubbing with a 4" drop in the rear.
Old 12-26-2019, 01:26 PM   #7
kens65fb
What 20 inch tires would fit best?
Old 12-26-2019, 08:18 PM   #8
60chevyjim
60chevyjim's Avatar
this is a good site to find out tire sizes . I use it a lot to compare tire sizes to put bigger tires on my stuff. I like the wheels you want !!
https://tiresize.com/calculator/
60chevyjim is offline   Reply With Quote
