Old 12-24-2019, 06:08 PM   #1
bigmac73
bigmac73's Avatar
rear brake line pic
can some one send me a pic of the rubber hose connection fitting from the two hard lines on the read axle tubes that connects to the frame rail long line that runs to the front of the truck, I think i am missing a fitting
or what connects to this end of the rubber hose, see pic
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-24-2019, 07:06 PM   #2
kwmech
Re: rear brake line pic
That end would go the steel line on the frame. The other end of the hose should be a built in female T where the lines come from each wheel cylinder
Old 12-24-2019, 09:57 PM   #3
HO455
Post Whore
HO455's Avatar
What year and model of truck? There are differences over the years and between K and C models and between coil and leaf springs on the axle end.
The first photo shows a 67 C10 axle set up. Which I believe is the same through 70.
In the second photo the larger hose is the brake hose. It goes through the frame above the spring to the fitting on the hard line. The correct hole in the frame should be D shaped. A clip like the front hoses (3rd photo red arrow) use will secure the hose to the frame. Red arrow in 2nd photo points to the location of the clip behind the frame stiffener for the spring base.
Good luck. I hope this helps.
RIP Bob Parks.
Old 12-25-2019, 03:55 PM   #4
bigmac73
bigmac73's Avatar
All thanks for the replies. I actually poured me a big Dickel and coke last nite and went out and just drank my drink and looked at the frame, and it hit me after a few sips. On how i took it apart a year ago. On my 72 there is a steel tab sticking out of the cross brace behind the differential like the last picture from HO455. and it all came together
Mike
Old 12-25-2019, 06:19 PM   #5
sprint_9
sprint_9's Avatar
Here are some stock photos I took before tear down. 72 C10
sprint_9 is offline   Reply With Quote
Old 12-25-2019, 08:47 PM   #6
scottofksu
scottofksu's Avatar
State Dependent Learning - You just had to get in the mindset you were in for tear down to remember! Dickel wins again!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 12-29-2019, 02:22 PM   #7
bigmac73
bigmac73's Avatar
HA HA
sprint 9 thanks for the pics , I am running new brake lines currently
Mike
