12-25-2019, 10:02 PM | #1 |
seats
has anyone tried to use car buckets like from a camaro , Chevelle , elcamino or something like that ? I realize the track wont just bolt in , but are they close enough that you could use new foam and covers for a truck on the frames ? seems the general used a lot of the same parts for several different things back then and the car stuff is a little cheaper and easier to find at reasonable prices . probably wishful thinking I know , but I have never had a set that I could take apart and compare before
12-28-2019, 10:18 AM | #2 |
Re: seats
Not even close in size or shape . also the Camaro seats would sit very loow in your truck .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
12-28-2019, 10:27 AM | #3 |
Re: seats
Take a look at this thread. It may give you some good ideas.
http://67-72chevytrucks.com/vboard/s...ighlight=seats
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
12-28-2019, 06:07 PM | #4 |
Re: seats
I put 68 camaro seats in my 67 gmc, I had to custom build bases but I like them .
12-28-2019, 09:54 PM | #5 |
Re: seats
thanks grumpy that's what I was wondering more than anything the size and shape . I thought if they were close maybe you could swap truck foam and covers . I kind of figured if I used them I would have to make platforms for the height .
12-28-2019, 09:58 PM | #6 | |
Re: seats
12-28-2019, 10:10 PM | #7 |
Re: seats
12-29-2019, 09:52 AM | #8 |
Re: seats
I hear you. That is exactly why I will be looking for something in the junk yard.
