Old 12-26-2019, 05:44 PM   #1
bb400ho
another gauge question
i am converting my 68 gmc dash from idiot lights to factory gauges. im not hooking up the battery gauge because i did a 5.3 swap with a stand alone harness do i still need to add the wire from the junction box with the 4 amp fuse? is this a constant 12v hot wire to the gauge cluster? thanks for any help
bb400ho is offline   Reply With Quote
Old 12-26-2019, 07:17 PM   #2
ray_mcavoy
Re: another gauge question
No, since you won't be using the battery gauge, you do not have to hook up either of the wires with the 4 amp fuses.
ray_mcavoy is offline   Reply With Quote
Old 12-27-2019, 09:50 AM   #3
bb400ho
thanks. i moved all the pins from the directions i found on this forum got t installed and everything works except the high beam indicator ill be looking at that today... its awesome to be able to access all the info here. thanks everybody
